Writing php script properly to show new description
Thread begun 1/27/2016 12:25 pm by mrobben375515 | Last modified 1/28/2016 8:00 pm by Ray Borduin | 1187 views | 3 replies |
mrobben375515
I did a pro-service to help me create a shipping dropdown. It works great for US shipments. I need to edit the dropdown for International shipping.
This is the code for creating the dropdown to show for shipping options and value:
<td class="eC_SummaryLabel">Shipping</td>
<td id="eCart1_JSON_Display_Shipping"><select name="shipSelected">
foreach ($ShippingOptions AS $key=>$val) {
<option value="<?php echo($key); ?>" <?php echo($key == $_SESSION['shipChoice']?"selected":""); ?>><?php echo($val[0]); ?>: $<?php echo(number_format($val[1]+3,2)); ?></option>
</select></td>
</tr>
How can I edit this so as to ship "Shipping $9.00" if there is no value because it was a domestic shipment? I have the cart adding $9.00 to the total, but I need to show the description of where the $9.00 came from in the shipping dropdown. I am attaching the cart.php and web credentials so you can see the site live if it helps.
On line 378 you could add:
if (sizeof($ShippingOptions)==0) {
$ShippingOptions["04"] = array("International","9.00");
$_SESSION['shipChoice'] = "04";
} else if ($_SESSION['shipChoice'] == "04") {
$_SESSION['shipChoice'] = "03";
Then add code to the confirm_cart.php so that it doesn't bother to try to recalculate shipping for international (line 54).
I've gone ahead and made those updates.
mrobben375515
Thank you so much for helping me with this. It is working fine now. I did notice that new users who are in the US are being registers their country as "United States" versus "US" the shipping is treating this as international shipping. I am going to fix the existing contacts who have their country as "US" to be "United States". I need to find the trigger that is associating "US" as the trigger for US shipping. When I search the cart.php code for "US", I only see it associated with the shipping parameters that are being sent to UPS's API. Is that the trigger? If I change the to read "United States", will that be accepted by the UPS API?
No, the UPS API requires the country code. It will only work with "US". The registration page must be storing the wrong value. Check the select list on that page.
