What is best CSS Code to use to make PowerCMS' Tables responsive??
Thread begun 1/27/2016 12:30 am by cldsk | Last modified 2/01/2016 11:24 am by Ray Borduin | 2757 views | 5 replies |
cldsk
Since PowerCMS has the insert table functionality, I have a lot of clients who use that to try and create their content placement - despite my objections and suggestions to it.
One main issue, is that it throws off the responsiveness of the site.
I am wondering what might be the best CSS code to use to allow the tables inserted via PowerCMS to be responsive? I have tried a couple things. Latest being:
@media screen and (max-width: 600px) {
table {
border: 0;
table thead {
display: none;
table tr {
margin-bottom: 10px;
display: block;
border-bottom: 2px solid #ddd;
table td {
display: block;
text-align: right;
font-size: 13px;
border-bottom: 1px dotted #ccc;
table td:last-child {
border-bottom: 0;
table td:before {
content: attr(data-label);
float: left;
text-transform: uppercase;
font-weight: bold;
But nothing seems to do the trick...any suggestions??
Can I get a sample url with a table on it that was added by powerCMS? I'll play around with it there to see if I can figure out a good CSS trick.
cldsk
Thanks so much - see the private message for details.
The real issue isn't the tables... it is the images inside the tables... and there is no real good solution I can think of since you don't know how many columns they might add.
I think to handle the tables you just add to your css:
table {
max-width: 100%;
But then you are going to have to add a media query and break point to really change the table at some size. Something like:
@media only screen and (max-width: 960px) {
table td {
display: block;
text-align: center;
table td img{
max-width: 100% !important;
height: auto !important;
Those two combined should do the trick pretty well.
cldsk
Thanks so much! I will give those a try
cldsk
that did seem to work :) Thanks so much!
