I need to track logins and whether they are successful or not
Thread begun 1/26/2016 8:44 pm by dionysus224892 | Last modified 1/27/2016 9:55 pm by Ray Borduin | 3215 views | 6 replies |
dionysus224892
I added an insert query just before the $Authenticate->execute() on my login page and it inserts into a login table the username, time and ISP of the person loggin in.
I wanted to test for a successful login and record that as well. Here's the code I added but I've not quite got it right because it always shows as successful even when I fail.
$InsertQuery = new WA_MySQLi_Query($eee);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "logins";
$InsertQuery->bindColumn("loguser", "s", "".((isset($_POST["user"]))?$_POST["user"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("logisp", "s", "". $_SERVER['REMOTE_ADDR']."", "WA_DEFAULT");
if ($SuccessRedirect) {
$InsertQuery->bindColumn("success", "i", "". 1 ."", "WA_DEFAULT");
} else {
$InsertQuery->bindColumn("success", "i", "". 0 ."", "WA_DEFAULT");
$InsertQuery->saveInSession("login");
$InsertQuery->execute();
What am I doing wrong?
That won't work... I think you can use that to insert every time. Just remove the if statement.
Then set up a failed redirect in your login that passes a url parameter. You can then apply a second insert based on the existence of the url parameter that inserts the failed log. You could also apply the delete record server behavior to delete the success record that was inserted. Just make sure to manually move around the code so that the order is:
1) insert success log, save id in session as "login" using the login button press trigger
2) delete the record with the id = $_SESSION['login'] using the url parameter for failed login as a trigger
3) insert failure log using the url for failed login as a trigger
4) user login code
dionysus224892
Thanks for getting back to me on these 2 issues... I will try to do what you're saying but how do I save the ID of the last inserted login entry in a session to delete it?
In fact, if I can get that ID, then I won't have to delete it but simple update it to 'failed', no?
Yes that actually would work. You could use an Insert and then an Update instead of an insert, delete, insert.
dionysus224892
Hi! Thanks for getting back to me. I'm just curious how to reference the ID ? I'm trying some code but it's not working. Please take a look.
After the insert code done at each login, whether successful or not, I added this :
$_SESSION['lastid'] = $InsertQuery->insert_id;
Then I have this at the top of the login page :
if ($_GET['error']) {
$UpdateQuery = new WA_MySQLi_Query($eee);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "logins";
$UpdateQuery->bindColumn("success", "i", "". 0 ."", "WA_DEFAULT");
$UpdateQuery->addFilter("logid", "=", "i", "".($_SESSION['lastid']) ."");
echo $UpdateQuery;
$UpdateQuery->execute();
$UpdateGoTo = "";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
Am I far off? This seems like it should work. Thanks!
You should have this line in the insert code:
that will save the inserted ID as $_SESSION['login']
dionysus224892
THANK YOU! It was there all along and I didn't realize what it was saving in the session. :)
