Sub Menus no longer pull up right info?
Thread begun 1/25/2016 10:56 pm by cldsk | Last modified 1/26/2016 7:33 pm by Ray Borduin | 1701 views | 2 replies |
cldsk
Hello, I am upgrading the site design of the site that Ray helped me create automated submenus with PowerCMS via a premium support ticket. I seemed to have everything working - but for some reason, while the code is showing to display the correct template page, the correct info isn't showing (it shows the same info for all the pages. not sure if this is something you could help with? See attachment for more details and login info.
Your menu links should just look like:
?Camp_Activities_Menu=3
In the one we worked on you were using the same page for multiple menus, so we had two parameters passed and some code on the top of the page to interpret it. In this example you only have one menu and don't have the code on top of the page, so you could either get and add the associated code, or update the link url as I've suggested to skip that step.
cldsk
Thanks so much - I was able to get that all fixed!
I will be contacting you soon for a premium support ticket for adding in the reordering option.
Thanks so much!
