Java Script Error on Insert Plug-in
Java Script Error when executing:Bindings->Framework->Insert Plug-in
Maybe try deleting the winfilecache .dat file. If that doesn't work I'll probably have to do a screen sharing session to debug it with you. Please post a US phone number or Skype contact information and I can call to debug it with you.
Debug info:
DWJavaScript.log:
JS Error:
Cannot find Server Behavior named 10-InsertPlugin.htm.
filename: C:\Users\Ron\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\DataSources\PHP_MySQL\Framework\FrameworkBuilder_Plugin.js
lineno: 55
Line 55:
function addDynamicSource(){
dw.popupServerBehavior('10-InsertPlugin.htm'); <--Line 55
FrameworkBuilder_Plugin.htm:
Non of the .js scripts are in ../../../Shared/Common/Scripts/
<TITLE>Insert Plug-in</TITLE>
<SCRIPT SRC="../../../Shared/Common/Scripts/dwscripts.js"></SCRIPT>
<SCRIPT SRC="../../../Shared/Common/Scripts/dwscriptsServer.js"></SCRIPT>
<SCRIPT SRC="../../../Shared/Common/Scripts/dwscriptsExtData.js"></SCRIPT>
<SCRIPT SRC="../../../Shared/Common/Scripts/DataSourceClass.js"></SCRIPT>
<SCRIPT SRC="../../../Shared/WebAssist/Framework/Framework_shared.js"></SCRIPT>
<SCRIPT SRC="FrameworkBuilder_Plugin.js"></SCRIPT>
</HEAD>
The only files I can find are in the C:\Users\Ron\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\ServerBehaviors\PHP_MySQL\WebAssist\Framework directory:
10-InsertPlugin.edml
FrameworkBuilder_Include.edml
FrameworkLibrary_Include.edml
Insert Plug-in_block1.edml
Insert Plug-in_Body.edml
It appears there were some missing files in the FreeTools installation. I've corrected the problem. Please try downloading and reinstalling the extension.
