image upload problem
Thread begun 1/19/2016 6:42 am by Jamie | Last modified 1/20/2016 1:25 pm by Ray Borduin | 1918 views | 3 replies |
Jamie
Hey Ray
With the attached _update page, all the image uploads work fine except for SubImage1 which is uploading the image fine, but its not adding the filename to the database (its adding '0') - not sure what I am missing ?
On the same page, If the box is checked it does add 1 to the column ProductInStore in the db which is good. but for some reason if the checkbox for the element ProductInStore is unchecked it should add a 0 to the db for the ProductInStore column but it isnt.
Many thanks
Jamie
The image field looks correct. Are you sure the database field is set up as a varchar?
The checkbox can probably be fixed by updating the binding from:
((isset($_POST["ProductInStore"]))?$_POST["ProductInStore"]:"")
((isset($_POST["ProductInStore"]))?$_POST["ProductInStore"]:"0")
Jamie
yes is definitely set to varchar
thanks re the checkbox
Jamie
I'd have to debug it. Maybe send me a Skype message tomorrow when you see we are both online and I'll take a look with you in a connect meeting.
