WA Server Validation Problem
Thread begun 1/18/2016 7:14 pm by salaroche | Last modified 3/01/2016 8:46 am by Ray Borduin | 5436 views | 18 replies |
salaroche
Hi:
I have used WA Server Validations before with very good results, but not this time.
I’m trying to double check whether two data entered in an insert page already exist in a particular table in the db. The first is the month in a date field and the second is the username.
The month I get using a SELECT MID(Date(Now()),6,2) AS month1 and the second is stored in $_SESSION[‘MM_Username’]
Then I have a recordset “parsedMonth2 with these parameters:
SELECT pslip.date, pslip.username
FROM pslip
WHERE pslip.username = akauser AND MID(pslip.date,6,2) = colname
Akauser uses $_SESSION[MM_Username’] as Runtime Value and colname uses $_POST[‘month1’] as Runtime Value.
The WA Server Validation uses Validation Trigger = Current page submit; validation type = Number; and Server variable = $totalRows_parsedMonth2; Format = English (1,000.00); Minimum = -1; Maximum = 0; and Allow decimals = All.
What am I not doing right here?
The Validation should allow users to enter their data when the conditions username AND MID(date,6,2) are not given together. As it is, however, the Validation never allows for entering the data, even when the table is empty. It always sends users to the error-message page.
Attached please also find a copy of the Insert page that contains the validation.
Any suggestions?
Thank you for your attention
The order of the code is wrong... you will have to move the server validation code from lines 10-23 below the recordset code it is trying to validate.... also remove that stray br tag on line 24.
salaroche
Ray:
Fantastic. Now it seems to be working OK.
Many thanks
salaroche
Ray:
After installing Data Bridge in CS6 the server validation is back to rejecting all entries in the pslip_insert form. I double checked that the validation code is below the parsedMonth2 recordset and double checked the validation configuration and everything seems to be OK. Yet the validation behavior is not accepting any new records, is not redirecting to the SecondPSMessage.php, and no records are being inserted in the pslip table.
After pressing the "Submit" button the pslip_insert.php reappears with all fields empty.
What has gone wrong?
Attached please find a copy of the Insert page in question.
Is there a url where I can see the problem? I'll have to debug it live.
salaroche
Ray:
Yes. Please see info below.
The validation works fine. The issue is the trigger for the insert. You have on line 201:
if (isset($_POST["Insert_x"]))
But your input button is named "Submit", so it should be:
if (isset($_POST["Submit_x"]))
salaroche
Ray:
Yes, I made the change you suggested and things seem to be getting back to normal in the slip_Insert page, but the validation still allows for inserting second records for the same month without alerting the user, which it shouldn't.
Please try entering a record for username lulu and you'll see. Lulu already has records entered for the month of February, so the validation should send the user to the SecondPSMessage page, but it doesn't. It accepts the record.
You are filtering your Recordset with the value of: $_POST['month1']
on line 133, but that value is never submitted in the form. I'm not sure what you are trying to validate against, but that is why it never has a result and always passes validation.
salaroche
OK. Can you see any error in this recordset? SELECT MID(Date(Now()),6,2) AS month1
It's giving a syntax error message: MySQL Error#: 1064. Yet when I test it it gives me the two digits for month.
