Webassist products not working in DW CC 2015
Thread begun 1/14/2016 9:57 am by tmcbinc99963 | Last modified 1/15/2016 9:24 am by Ray Borduin | 2959 views | 5 replies |
tmcbinc99963
Recently upgraded to DW CC 2015 to use Bootstrap.
Used DMXzone Extension Manager to load WADataBridge123.zxp, UE401.mxp and WAeCart609.zxp. Uploaded Deprecated Server Behavior from Adobe AddOns
They uploaded when DW was reopened and all the extensions are there. However, I've tried using several of the extensions and none of them work. Most windows either open and close immediately, nothing happens at all, or I get error messages. For example, for the eCart Object I get 'DLL.checkSerial is not a function'. For the Image Resizer, I get 'Image Cache objectTag Error ReferenceError: WADA_Bundle is not defined.
Also received the error, my page is not a php page, though I've created New PHP page, PHP is selected in Managed Sites, and all my databases are accessible through Databases panel.
Though I've installed the Server Behavior fix, in DW > Window > Extensions, it still says 'no extensions available'. It also doesn't show up in the DMXzone Extension Manager either in CC or CC 2015. Not sure if this means anything.
Lastly, DMXZone indicates the Server Behavior fix is deprecated in favor of their updated extensions. Should I install these instead?
Please advise.
It sounds like you may not have gotten the extensions installed properly. Our extensions definitely work with CC 2015. I use it almost exclusively.
1) You still have to install the deprecated server behaviors... their new one only works with their stuff
2) You should use the DMX Zone Extension Manager to install the extensions (Adobe dropped support for theirs)
3) Make sure you have downloaded the latest version of our extensions.. older versions won't work with Dreamweaver CC versions
tmcbinc99963
Downloaded the zxp again and used DMX Extension Manager to install - it shows up in the Manager Window with the other WA extensions.
WA Extensions are: Data Bridge v1.2.3, UE v4.0.1 and eCart v6.0.9
All problems and errors previously stated still exist.
Please post a US phone number or skype contact information and I'll do screen sharing with you to look into the issues and help you get everything installed properly.
tmcbinc99963
Will do.
The issue was that Universal Email stand alone was installed with the other extensions... Only Data Bridge, Design Extender, eCart 6, MySQLi Server Behaviors, and Free Tools will work in CC 2015. Installing any others will cause errors.
