PowerCMS
Thread begun 1/13/2016 9:49 am by russb335115 | Last modified 1/14/2016 2:23 pm by Ray Borduin | 2453 views | 4 replies |
russb335115
PowerCMS & uploading PDF files
I'm trying to upload a 30meg PDF file through the link function in PowerCMS. Smaller files upload fine but I can't upload this file. What do I need to change to fix this. I already check the limit with my host provider and it's set to 40megs.
Check your php.ini file for the values of:
upload_max_filesize = 10M
post_max_size = 10M
you can check by adding this to a page:
phpinfo();
And then look at those settings.
russb335115
Where in the page should I add it and then do I see the results?
russb335115
Okay here is what I see.
upload_max_filesize 40M 40M
post_max_size 8M 8M
Also the file is a PDF that is 30M and is being upload through KFM
So it looks like your post_max_size is the one that has to be updated... talk to your hosting provider about how to get it adjusted.
