Not all select menus working on search page.
Thread begun 1/11/2016 6:03 pm by illbe322016 | Last modified 1/12/2016 5:28 pm by Ray Borduin | 1285 views | 2 replies |
illbe322016
I have a search page that queries firearm specs (make, model, barrel length, etc.) and refreshes the results on the same page . One of the database driven select menus is for New or Used firearms. Any of the other select menus query correctly and produce correct results, the newUsed select menu does not seem to work at all even though I can see no differences in the code from one select menu to another. When I choose New or Used and click search it also does not retain the selected value as the other select menus do upon refresh. The query string seems to be correct (http://www.senecagun.com/searchResults.phpS_make=&S_model=&S_caliber=&S_type=&S_typeDefined=&S_newUsed=USED&S_itemID=&Search=Search) and I have tried manually entering New or Used after "S_newUsed=" still to no avail, it still returs all records new and old. I have sent my search page code and the include for the select menus, please give me a hand here I'm running out of hair :-).
Thanks in advance
Tom
On line 26 of the results page you have the form element name as "S_NewUsed"... but the form element is actually named "S_newUsed"
On line 105 of the search page you have: $_GET["newUsed"] but that too needs to match the form element name and should be $_GET["S_newUsed"] the two places it appears.
illbe322016
Thank you so much Ray, you saved my ass again.
All the best
Tom
