showing content
Thread begun 1/08/2016 1:18 am by Jamie | Last modified 1/12/2016 1:43 pm by Ray Borduin | 1833 views | 6 replies |
Jamie
showing content
Am trying to get this to work but cannot get the RS correct.
Am looking to shjow 'From' if te the product item has an option associated with it.
<?php if ($Categories->getColumnVal("OptionGroupID")) { ?>
From
<?php } ?>
This is the RS
$Categories = new WA_MySQLi_RS("Categories",$DBConnection,0);
$Categories->setQuery("SELECT productcategories.CategoryName, productcategories.CatPermalink, productcategories_2.CategoryName AS parentcategoryname, productcategories_2.CatPermalink AS parentpermalink, products.*, productmanufacturers.ManufacturerName, options.* FROM productcategories LEFT OUTER JOIN productcategories AS productcategories_2 ON productcategories.CategoryParentID = productcategories_2.CategoryID LEFT OUTER JOIN products ON productcategories.CategoryID = products.ProductCategoryID LEFT OUTER JOIN productmanufacturers ON products.ProductManufacturerID = productmanufacturers.ManufacturerID INNER JOIN options ON products.ProductID = options.OptionGroupID WHERE productcategories.Live = 1 AND productcategories.CatPermalink = ? AND products.ProductLive = 1 ORDER BY productcategories.CategoryOrder ASC");
$Categories->bindParam("s", "".$_GET["perm"] ."", "-1"); //WAQB_Param1
$Categories->execute();
How this is set currently is stopping any items from being returned let alone not adding From if appropriate
You have:
It should be something like:
INNER JOIN options ON products.ProductID = options.OptionProductID
Jamie
ok, have tried that
$Categories->setQuery("SELECT productcategories.CategoryName, productcategories.CatPermalink, productcategories_2.CategoryName AS parentcategoryname, productcategories_2.CatPermalink AS parentpermalink, products.*, productmanufacturers.ManufacturerName, options.* FROM productcategories LEFT OUTER JOIN productcategories AS productcategories_2 ON productcategories.CategoryParentID = productcategories_2.CategoryID LEFT OUTER JOIN products ON productcategories.CategoryID = products.ProductCategoryID LEFT OUTER JOIN productmanufacturers ON products.ProductManufacturerID = productmanufacturers.ManufacturerID INNER JOIN options ON products.ProductID = options.OptionProductID WHERE productcategories.Live = 1 AND productcategories.CatPermalink = ? AND products.ProductLive = 1 ORDER BY productcategories.CategoryOrder ASC");
and it errors saying unknown column as per http://clients.motley.site/sewards/shop/beds/bedsteads
in the db, there is no row for OptionProductID in the options table.....so I tried it with OptionID and I get the same result as with OptionGroupID (which is no results)
You probably have to join the options groups table first.
LEFT OUTER JOIN optiongroups ON products.ProductID = options.OptionProductID LEFT OUTER JOIN options ON options.OptionGroupID = optiongroups.OptionGroupID
Jamie
sorry, am still getting an unknown column error
rs has been updated to
$Categories->setQuery("SELECT productcategories.CategoryName, productcategories.CatPermalink, productcategories_2.CategoryName AS parentcategoryname, productcategories_2.CatPermalink AS parentpermalink, products.*, productmanufacturers.ManufacturerName, options.* FROM productcategories LEFT OUTER JOIN productcategories AS productcategories_2 ON productcategories.CategoryParentID = productcategories_2.CategoryID LEFT OUTER JOIN products ON productcategories.CategoryID = products.ProductCategoryID LEFT OUTER JOIN productmanufacturers ON products.ProductManufacturerID = productmanufacturers.ManufacturerID LEFT OUTER JOIN optiongroups ON products.ProductID = options.OptionProductID LEFT OUTER JOIN options ON options.OptionGroupID = optiongroups.OptionGroupID WHERE productcategories.Live = 1 AND productcategories.CatPermalink = ? AND products.ProductLive = 1 ORDER BY productcategories.CategoryOrder ASC");
LEFT OUTER JOIN optiongroups ON products.ProductID = optiongroups.OptionProductID LEFT OUTER JOIN options ON options.OptionGroupID = optiongroups.OptionGroupID
It is difficult because I don't have your database and am guessing column names.
Jamie
thanks for your helpo...all working now
