Applying template causes error, but page works after applying Framework Theme
Thread begun 1/07/2016 7:18 am by mrobben375515 | Last modified 1/07/2016 5:34 pm by Ray Borduin | 2353 views | 3 replies |
mrobben375515
When I apply my template to a page and form created with Forms/Insert Form I get an error about the TotalColumns that is a quick cart call that is inside the template itself. However, when I apply the Framework theme associated with the template, the page loads, but loses the styling on the form. What is wrong with the template? Please see attached txt file for additional notes and files that are questioned.
Your editable region names don't match up.
In: main_fw_theme.dwt.php you have: "head", "content", "footer"
but in: main.dwt.php you have: "headLine", "content", "footer"
The names of the editable regions need to match in order for the page to be constructed properly by framework builder.
mrobben375515
Thank you Ray. The formatting looks more consistent on the page after I apply the framework theme. But I am still getting an error on the page when I only apply the dw theme page only. See the link in the PM. I am assuming something is wrong with my template.
This error means that the eCart require_once() code isn't on the page. It is probably on the template but not on the page itself and Dreamweaver won't copy over server side code from the template to the derived pages. That is one of the advantages of WebAssist themes and explains why it works with the theme applied.
