Can I display the value associated with a select list item in an Add to cart button
Thread begun 1/06/2016 11:37 pm by Brendan | Last modified 3/24/2016 10:31 am by Ray Borduin | 3359 views | 4 replies |
Brendan
The price in my ATC is based on the value associated with a select list in the button. Since the select list items do not include the price, is there any way to display the value of the selected item on the page before the user clicks submit?
To make this a little more tricky (to me) - I have a js calculation as part of this from a premier support session
It can be done with Javascript on the page, but since you have the calculation based on the text field as well as the select list it can be kind of complicated.
This is something I could do for you in a premier support ticket.
Brendan
Ray, hoping you could help with this. You helped me create the calculation in PM, I have had a couple of transactions fail from what i expect are totals with 3+ decimal places. I'm trying to restrict the result of the formula to 2 decimal places.
<script>
function updatePrice() {
var selVal = document.getElementById('grossSelect').options[document.getElementById('grossSelect').selectedIndex].value;
if (selVal == '0') {
document.getElementById('enterGross').style.display='block';
baseVal = 660;
enteredAmount = document.getElementById('gross').value;
enteredAmount = enteredAmount.replace(/[^\d]/g,"");
enteredAmount = parseInt(enteredAmount);
if (enteredAmount > 500000) {
enteredAmount = enteredAmount - 500000;
baseVal += 35 * (enteredAmount/100000);
document.getElementById('calcTot').innerHTML= baseVal;
} else {
document.getElementById('enterGross').style.display='none';
document.getElementById('calcTot').innerHTML=selVal;
</script>
Try:
<script>
baseVal = 660;
document.getElementById('calcTot').innerHTML= baseVal.toFixed(2);
} else {
document.getElementById('calcTot').innerHTML=selVal.toFixed(2);
</script>
Brendan
Thanks Ray, that worked perfectly!!
