No Divs and Tables' Border Colors
Thread begun 1/05/2016 11:46 pm by salaroche | Last modified 1/11/2016 7:09 pm by Ray Borduin | 2585 views | 9 replies |
salaroche
No Border Colors in Divs and Tables
Hi:
I created yet another Search-Results-Details-etc. sequence using the DataAssist Wizard and everything is OK, but when I insert Divs or Tables in the WADADetails Container their borders don’t show on the browser. The Divs and Tables' borders appear well on DW’s window, but not on the browser.
There is no problem with the contents I enter in the Divs and Tables either; they show well on the browser, but not the borders. Is there anything making the WADADetails Container color-blind on the browser?
Any suggestion on how to solve this problem?
Thank you for your attention
If you post a URL so I can see a page you are working on I might be able to suggest what to update in the css.
salaroche
Ray:
Please see private message below
The CSS seems incorrect.
You have this css to create the border:
#main #bodyMain .WADADetailsContainer mm_hiddenregion #WADADetails #decorDiv1 {
You need to remove the "mm_hiddenregion" part of the style definition... it is breaking it.
salaroche
Ray:
I had already removed that, but I did it at the moment of inserting the Div/Table. This time I removed it using the "Edit Selector" function and now the borders are visible in the browser.
salaroche
Ray:
Please see private message below.
What CSS do you think is adding the gold border? I don't see any class definition for that cell.
salaroche
The CSS name is: Traditional_Pacifica.css
The Selector's name is: #main #bodyMain .WADAInsertContainer #WADAInsertForm #decDiv04
The table name is .WADADataTable
Both the Div and the table are inside the Traditional_Pacifica.css
That selector code isn't in the Traditional_Pacifica.css file... maybe you haven't uploaded it.
salaroche
Ray:
You were right. I hadn't updated the WA_DataAssist folder.
Thank you for your attention.
