I just installed Power Gallery and was editing settings in Grid + Full Size design and now get error messages like this: Warning: scandir( / / /galleries/temp_editing/css/themes/) [function scandir]: failed open dir: Invalid argument D:\Domains\frank
Thread begun 1/05/2016 2:19 pm by birdscreen398247 | Last modified 1/06/2016 3:33 pm by Ray Borduin | 2859 views | 5 replies |
birdscreen398247
I just installed Power Gallery and was editing settings in Grid + Full Size design and now get error messages like this: Warning: scandir( / / /galleries/temp_editing/css/themes/) [function scandir]: failed open dir: Invalid argument D:\Domains\franklinhaa
I was changing fonts and colors. After previewing them, I click on settings again to make more changes and I got a bunch of these error messages, all involving styler.php. I replaced the styler.php file to no avail.
Warning: scandir(../../../galleries/temp_editing/css/themes/) [function.scandir]: failed to open dir: Invalid argument in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 132
Warning: scandir() [function.scandir]: (errno 22): Invalid argument in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 132
Warning: Invalid argument supplied for foreach() in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 133
Warning: fopen(../../../galleries/temp_editing/css/themes/dark.css) [function.fopen]: failed to open stream: No such file or directory in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 155
Warning: filesize() [function.filesize]: stat failed for ../../../galleries/temp_editing/css/themes/dark.css in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 156
Warning: fread(): supplied argument is not a valid stream resource in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 156
Warning: fclose(): supplied argument is not a valid stream resource in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 157
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../../galleries/temp_editing/admin/design.xml" in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 160
Fatal error: Call to a member function asXML() on a non-object in D:\Domains\franklinhaas.com\wwwroot\PowerGallery\webassist\plugins\stylerPG\styler.php on line 180
It looks like there are some issues it is having determining your installation folder and file path. If you give me a url and FTP access I'll debug it and figure it out for you.
birdscreen398247
See private message.
The code wasn't properly removing the temporary folder that holds the gallery design while editing. I updated the styler.php page so that this shouldn't happen any more.
birdscreen398247
I re-installed the program files earlier today, so I may have overwritten your fix. I was able to go in and do one edit of the settings and save it, but when I tried to edit settings some more, I got the same error messages.
Let me know if that is the case. I will stay away from it until I hear from your and then copy the styler file to a backup location for future repairs.
That must be what happened... I've gone ahead and uploaded it again and it appears to be working again now.
