MySQLi Update Record Not Working NOR Doing PHP Edits
Thread begun 1/04/2016 8:03 pm by TonyE | Last modified 1/06/2016 3:39 pm by Ray Borduin | 3738 views | 4 replies |
TonyE
I had the MySQLi update record function working but I added some PHP edits to the inputted form data and now updates don't work nor are my PHP edits being processed. This problem is driving me crazy! It all worked when I used Dreamweaver's update record function. I'm not sure if its because the "rel2abs" is not in my program or what. I've attached my update program code for someone to look at.
Your update server behavior is filtering the clnt_no with the value: $_GET['clnt_no']
However your form doesn't pass the clnt_no value forward in the action. The solution is probably to remove the form action attribute from the form and then it will pass the url parameters with the form submit automatically... or better yet use: $_SESSION[cclnt_no] so that the end user can't change it in the url and update a different account.
TonyE
Ray, thank you for your prompt reply. I made the change you suggested and the update didn't work. Then I changed the MySQLi Update Record Trigger parameter to "current page submit" from "Button Submit Pressed" and it worked along with your suggestion. I still have a problem that my PHP edits in lines 192-296 in my attached code are not being executed BEFORE the MySQLi Update Record code is performed. I need that code to be executed BEFORE the MySQLi Update Record code. When I move the MySQLi Update code after my PHP edits the MySQLi Update server behavior disappears from my behaviors list. There has to be a way around this. Is there a more detailed Help write-up on this behavior other than what's presented in the server behavior? I've spent a great deal of time on this issue.
It should work if you move your code up to the top of the page instead of moving the insert code down into the body of the page.
TonyE
Ray, that suggestion worked. Again, thanks for your assistance!
