add radio select ecart
Thread begun 1/03/2016 11:38 pm by mrobben375515 | Last modified 1/04/2016 11:26 am by Ray Borduin | 4082 views | 8 replies |
mrobben375515
I have a products detail page that lists prices based on quantity breaks. I have the price breaks displayed in a radio group. I have an add to cart button on the page that correctly passes the product to the cart, but I can't figure out how to pass the price and quantity the user selected. This is a private site so I am attaching the site credentials and the page in question as an attachment in the PM.
You should be able to set the value of the radio buttons to contain an ID that you can use after submit to look up the associated price. Then in the Add to cart bind the price and quantity values from that lookup recordset.
mrobben375515
Thank you Ray. I will update the input line like this <input type="radio" name="retailprice" value="priceID" id="retailprice_0"> where the value = the pricing record set ID. I already have a record set that holds the price breaks.I now added another record set to lookup the price when the user selects the quantity break. However, after I did this and updated the eCart Add To Cart (ecart1) SB to pass the new. However, when I click the "add to cart" button I am not sent to the cart. I just stay on the products_detail.php page. Any idea what I missed? Does tge
If the radio has: name="retailprice"
Then you would reference it with $_POST['retailprice'] in the parameter.
The blank line of code might be preventing the redirect... make sure the blank lines are removed.
mrobben375515
Should I bind the pricing ID to the "value" in the radio group also?
Yes, but it does seem like you will need two recordsets... One that returns all the results to display the radio buttons, and the second one to lookup the selected value and use it to add to the cart.
mrobben375515
I made the changes you suggested. However, I seem to be having the same problem, the page is not advancing. If it helps to look at the file, I am attaching the products_detail.php page and the credentials to access the site if needed.
The blank line of code on line 89 could be preventing the redirect. Try removing that.
mrobben375515
Never mind, I found the problem. My value was from the wrong table. The page works correctly now. Thank you for your help.
