Download link not available in the Store and email
Thread begun 1/02/2016 12:15 pm by massimo173451 | Last modified 1/04/2016 11:13 am by Ray Borduin | 2643 views | 5 replies |
massimo173451
Download not available in the Store and email link
In the web store when try to download the digital products, is not able to do this, nothing happens and no error message are showed. The same behaviour when receive the link sent by email. Any suggestion are appreciated for fix the issue??
Massimo
I'll need to debug the php code... Can you send a sample url and FTP access in the private area and I'll debug it to figure out what is going on.
massimo173451
As request for accessing and try to download a digital product.
I was able to fix the problem by updating the file: webassist/file_manipulation/helperphp.php
massimo173451
Ray was corrupted???
Your server wasn't including a "/" at the end of the folder reference, and it usually does. I'm not sure the cause, but I updated the code to check and add the slash if it wasn't present.
