Year defaults to wrong century when INSERT on a Date field
Thread begun 12/30/2015 8:26 pm by LionsMane | Last modified 12/31/2015 3:46 pm by Ray Borduin | 594 views | 1 replies |
LionsMane
Year defaults to wrong century when UDPDATE on a Date field
When UPDATEing a typically American formatted date (12/25/60) into a Date field, the year seems to be getting converted to 2060 instead of 1960. Any idea why this happening and how to correct it?
You need to use a four digit year... This is what is commonly referred to as the Y2K issue. Code has no way of knowing what you mean with two digit years.
what would you expect 12/25/99 to be? is your date always in the future. I suppose we could hand code a solution for you that would add the 20 in front of any year input so that the user could input a two digit year and it would convert to a four digit year in a premier support ticket, if that is indeed what you want or need.
