Hi - need help using MySQLI server behavior MySQLI log user followed tutorial by Kate Ford created MySQLI db connection tests out correctly set record set user login info tests correctly assume need set Data Bride login FORM login user login user ‘F
Thread begun 12/22/2015 9:19 am by jhaa32156951 | Last modified 12/28/2015 8:48 am by Ray Borduin | 2527 views | 4 replies |
jhaa32156951
Hi - need help using MySQLI server behavior MySQLI log user followed tutorial by Kate Ford created MySQLI db connection tests out correctly set record set user login info tests correctly assume need set Data Bride login FORM login user login user ‘Find Re
Hi - need help using the MySQLI server behavior MySQLI log in user . I have followed the tutorial by Kate Ford.
I have created the MySQLI db connection it tests out correctly. I then set up the record set that the user login
info is on it tests correctly. I assume that you need to
set up the Data Bride login FORM to login the user. On the login user ‘Find Record’ tab I set the the user name and password
to the corresponding columns in the MySQLI record set. In the ‘Store Values’ tab i set the save session to the same name as the db column
for username( which in my case is a membership NUMBER) and the user password . When i try logging in on the newly created login
page i receive a SEVER ERROR . Can you please help me to get this to work. I have attached the file. Thanks, John
You have set the filter values to the values from the recordset instead of the form.
Go back into the Authenticate User server behavior and on the ‘Find Record’ tab set the values to the corresponding FORM Elements, not recordset columns.
jhaa32156951
OK thanks Ray . Now not redirecting properly - URL too large. Thanks
It is probably redirecting back and forth between pages. Please attach a copy of the page it is redirecting to as well as the current page for me to look into this.
jhaa32156951
Ray thanks all is working properly now.
