Help with repeating tables
Thread begun 12/22/2015 9:06 am by iain331081 | Last modified 12/23/2015 5:01 pm by Ray Borduin | 4796 views | 8 replies |
iain331081
A while ago I got some help to display the first record in a recordset in one part of a page, and the next x records in another part, and the next y records in a third part.
I have been looking at combining that with the repeating tables function, but not quite got it, and could do with a little help.
Details below....
You had some leftover code from the other page on this one. I removed it and updated the number of rows to get it working properly.
iain331081
Thanks Ray - really sorry, but I think I overwrote it with my old version.
Could you re-upload the updated version if you still have it?
Thanks.
I just re-uploaded it
iain331081
Thanks Ray - just looking at the code to try to see what's doing what.
Is that using a different method? I thought the other one used data seek to show the first record:
mysql_data_seek($rsProductUpdates, 0);
$row_rsProductUpdates = mysql_fetch_assoc($rsProductUpdates);
And subsequent records (e.g. 2-10):
<?php for($i=1;$i<=10;$i++) { ?>
mysql_data_seek($rsProductUpdates, $i);
With this page it looks like you added LIMIT 21 at the end of the SQL to control how many records appear on the page, and 20 iterations in the repeating table.
But what makes it show the first record at the top, and then records 2-21 in the repeating table?
I'm just wondering how much of a pain it might be to have more than one repeating table on the page to break it up and make it look a little less repetitive, for example:
1 story at the top showing record 1
Repeating table showing records 2 - 5 in a single row of 4
Repeating table showing records 6 - 15 in 4 rows of 2
Repeating table showing records 16 - 19 in a single row of 4
Repeating table showing records 20 - 29 in 4 rows of 2
Or something like that at least.
Would it just be a case of adding more repeating tables, with the specified number of iterations, and altering the LIMIT in the SQL?
Also, I'm using Substr(update_details, 1, 140) AS summary text to limit the text to the the first 140 characters of the news item. Do you know any little tricks to do that without truncating in the middle of a word, i.e. 140 characters + however many before the first blank space, period?
I add limit 21 to the query for efficiency. It would still only display the 21 without it, but since I know only 21 records are being shown there is no reason to retrieve more.
The first record is always first, so I don't need to do anything to show the first record.
On line 238 I add a call to mysql_fetch_assoc() to move to the next record (second) before starting the loop:
The number of rows actually displayed is controlled by line 117 in the loop settings:
$RepeatSelectionCounter_1449935665360_Iterations = "20";
To have it not break in the middle of a word, I'd return more characters than you need in the sql query, maybe change it to 160... then add a function to the php:
function truncate($str, $width) {
$str = str_replace("\n"," ",$str);
    return
strtok(wordwrap($str, $width, "...\n"), "\n");
And then display the column using that function like:
<?php echo(truncate($row_rsProductUpdates['summarytext'], 140)); ?>
Breaking it into multiple repeated regions shouldn't be an issue... just lower the number in the first one on line 117 and add more repeated regions for the others. You wouldn't really need to change the limit in the SQL unless you were displaying more than 21 total rows.
iain331081
Thanks Ray - the truncating of words is working great at index5.php.
I have tried adding another repeated region at index6.php (lines 380-500) but must have something wrong. Its drawing a blank page due to a syntax error at line 495.
I thought maybe I needed to delete line 354:
<?php } // Show if recordset empty ?>
As that is only needed once at the end, rather than after each repeating region.
It didn't report any errors, but the page then only displays the first record.
I have attached a copy below.
Hopefully this is nearly it - once I have a couple working I can play around with others to get to a final layout for the page.
You need an end for every start... in this case you had three ends and one start and no end for the show if recordset not empty.
I've fixed it on your site, but debugging hand coding is a bit beyond what we usually do on this forum. In the future I'll have to ask you to sign up for premier support to help you debug things like this.
iain331081
Thanks Ray - really appreciate that. In future do let me know if something crosses the line to a premium ticket.
I don't know if DW is messing about, but despite being careful I managed to overwrite that again - could you reupload it again?
Thank you.
Edit - think I fixed it at index201.php
