url elements not showing
Thread begun 12/16/2015 1:00 am by Jamie | Last modified 12/18/2015 9:55 am by Ray Borduin | 1459 views | 2 replies |
Jamie
Hey Ray
Not sure why the element 'ManPermalink' is not being shown on the front end of the site for this:
<a href="shop/<?php echo($FeaturedProductPanel->getColumnVal("ManPermalink")); ?>/<?php echo($FeaturedProductPanel->getColumnVal("ProdPermalink")); ?>" class="responsive-picture featuredProductImage">
On the live site this looks like http://www.domainname.co.uk/shop//productname which, as you can see, omits the brand name between shop and productname
The recordset is
$FeaturedProductPanel = new WA_MySQLi_RS("FeaturedProductPanel",$DBConnection,1);
$FeaturedProductPanel->setQuery("SELECT products.*, productmanufacturers.ManufacturerName, productcategories.CategoryName, (SELECT sum(OptionPrice) FROM optiongroups INNER JOIN options ON options.OptionGroupID = optiongroups.OptionGroupID WHERE OptionProductID=ProductID) AS OptionPrice FROM products INNER JOIN productmanufacturers ON products.ProductManufacturerID = productmanufacturers.ManufacturerID INNER JOIN productcategories ON products.ProductCategoryID = productcategories.CategoryID WHERE products.ProductLive = 1 ORDER BY Rand()");
$FeaturedProductPanel->execute();
cheers
Jamie
The only thing I can think of is to make sure the column name you entered is correct (case sensitive). You could also try testing that SQL statement in phpMyAdmin to make sure it returns the expected result.
Jamie
Figured it out. In the select statement I had productmanufacturers.ManufacturerName so changed it to productmanufacturers.*
Cheers
