database.php will not ftp to hosted site...cannot install
Thread begun 12/09/2015 7:17 am by Dennis | Last modified 12/09/2015 10:43 am by Ray Borduin | 2543 views | 6 replies |
Dennis
I cannot install Powergallery.....looks like the database.php module will not ftp and when I look at database.php on my local unzipped module it looks like I should have a connnections.php module that I do not have eoither. Ideas?
No matter what I do, I cannot FTP database.php onto my production server. I have installed powergallery just fine on my local server but cannot complete the install on my production server because database.php will NOT ftp to the production server.
I called GoDaddy....they indicated that database.php did not meet their malware standards for some reason. They dropped the database.php into the powergallery folder and allowed me to go forward.
NOW: I cannot get past the instsall screen where you enter your hostname, database, username and user password. The followup screen says it doesn't exist. Ideas?
I can get it installed for you if you give me FTP access... I'll give it a try.
Dennis
Credentials
I am posting my credentials in the private message.
I've updated the database.php file so that the installation wizard should run correctly now. Please try again and let me know if you have any issues.
Dennis
Install problems
Thanks...a little farther.... now I get the following message when trying to access the powergallery Admin:
Warning: require_once(images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/content/70/11048770/html/powergallery/admin_gallery/global.php on line 32
Fatal error: require_once() [function.require]: Failed opening required 'images/installed.png' (include_path='.:/usr/local/php5_3/lib/php') in /home/content/70/11048770/html/powergallery/admin_gallery/global.php on line 32
That is another security mod thing... I've fixed it on your server.
Dennis
Done....I tested it......added my first gallery image and seems to be set to go....THANK YOU.... not sure what you modified by I will save the powergallery folder for backup....
