Powerstore users_registration.php from issue
Thread begun 12/07/2015 1:45 pm by Jared Lui | Last modified 12/07/2015 2:58 pm by Ray Borduin | 586 views | 2 replies |
Jared Lui
I've updated my users_registration.js file so that when I select "Company" from the Access Group select field that a third version of the registration form is visible.
I made a copy of the registration form and edited it giving it an ID of CompanyRegistrationForm that is pulled up using the javascript file mentioned above and that works. I set the input button ID to RegistrationComp and copied the register insert code and edited it to match the button ID.
My problem is that the form is not updating the database. The other two, the original registration form and the admin form still function correctly. I do not see what I am missing or went wrong.
I'm including the file. Can you easily spot the problem?
Thanks.
The server validation is probably preventing it. Line 103 should probably read:
if (isset($_POST["Register"])) {
Jared Lui
That worked. Would never have found that.
Thanks Ray!
