coupon causing checkout failure
Thread begun 12/07/2015 8:53 am by stuff223820 | Last modified 12/07/2015 2:47 pm by Ray Borduin | 4175 views | 10 replies |
stuff223820
Hi Ray
I have a challenge with any coupons i build and try to let client's use. I have tried adding the product as a single add to coupon, the "add all" method and even just on a single product and i just can not get the transaction to complete. the user is sent to papal - express guest or account log in, enters info and then is returned to my store with a "transaction not completed" error. Please help.
See code in attach
www.dirtymonkeykustoms.ca
It looks like maybe it was a percentage based coupon and it caused the total to have too many decimals.... I've updated your cart to only pass 2 decimals in the amounts, please give it another try and see if that fixed the problem.
stuff223820
Hi Ray
One was a percentage - 25%. the other was $2.00 off an order of $ 38.99 or more on select products. i will give it a try
If it doesn't work, post back with the coupon code and product you tried to purchase so I can reproduce the error.
stuff223820
Hi Ray
It will not even pass to paypal now. I create a $2 coupon for purchase over $39.98 on a single item..
go here and select "the Striper" coffee mug and add 2 to cart. https://dirtymonkeykustoms.ca/products_results.php?Search=1&ProductCategoryID[]=32
Sorry about that... I accidentally added the two decimals to the quantity field as well... please try again.
stuff223820
no, still fails. see code in PM.
["ECO_Process_Result"]=> string(2247) "2015-12-07T22:08:11ZFailure4935093f6f721Invalid DataItem total is invalid.10426Error63.018308778" ["WA_Store_Cart_MultipleShipping_Rates"]=> array(0) { } ["WA_Store_Cart_MultipleShipping_SelectedRate"]=> array(0) { } }
stuff223820
i wonder if it has something to do with the "additional item charges" option we added?
I think I got it this time... please try again. It wasn't passing the adjusted price properly.
stuff223820
You nailed it!! thanks Ray - works great. Which files did you update so I can make sure i update my local versions?
One last bug i spotted - maybe no big deal. When i clear cart, then refresh my page in the browser, i see the enclosed errors..
