products with two different tax
Thread begun 12/05/2015 1:57 am by QuiruNet | Last modified 12/10/2015 5:26 pm by Ray Borduin | 4239 views | 11 replies |
QuiruNet
products with three different tax
Hi, i have a client that he has to apply three different taxs to his products, one for the alcohol (21%) and other (10%) for food and other (4%)...how can apply it to ecard?.
I'd add a column to the shopping cart for TaxRate... then add a calculation to the cart for TaxTotal=TaxRate*TotalPrice
Then add a tax rule to the cart to add the total of the column TaxTotal as the amount.
QuiruNet
info
but in the data base, i have to put..the tax into the category field?
You can put the tax into the category field, or into the product field, or into an associated table for tax. The important thing is that when you add the item to the cart you also add the tax rate associated with that item so that the correct tax amount can be charged.
QuiruNet
info
i did it, but how i can put the information showing the total tax in the sumary?
When you add the tax rule to the cart it should automatically include it in the summary.
QuiruNet
INFO
it doesnt appear in the summary.
thanks
In the ecart you have to click the plus button on the tax tab and add the total of the ivaTax calculation as a tax charge. Then it should appear on the page.
QuiruNet
help
can you help to do the steps. Thaks
Go to the Tax tab and click the plus button.
Give it a name, and add a trigger... you can use: Total number of unique items in the cart > 0
Then for the calculation use: Based on column total and select the lvaToal column.
