Dynamic Connections generation error message
Thread begun 11/29/2015 1:32 pm by Zafar Iqbal | Last modified 12/14/2015 10:14 am by Ray Borduin | 6951 views | 11 replies |
Zafar Iqbal
Dynamic Connections generate error messages
I am having this error as I open up Dreamweaver and without opening any page switch the "Bindings Panel" please take a look at image which I have sent you, and I do not see the connection, but as I refresh the panel then the connection shows up, and also there are 2 Dynamic Connections, one is SQL Connection and the other is SQLi Connection, if I use SQL Conncection, it does not shows up when I use SQLi Extension, and when I make Connection using SQLi Connection it and use with DataAssit "Database" it give me Server Error at runtime.
Try closing Dreamweaver and deleting the filecache .dat file. That should get rid of the error within Dreamweaver.
The runtime error implies an issue with the connection itself not working. Are you sure the username and password are correct? Do you have a dollar sign in your password? That can cause issues as well.
Zafar Iqbal
I tied everything which I am told to do by your help system called Installation Issues.
I deleted the file cache still did not work, I did everything as this page of your website is telling me installation issue: http://www.webassist.com/tutorials/Common-installation-issues, the username and password is correct and I did not use any $ sign in my password.
Can I get FTP access to your server? I'll debug and see if I can figure out why it is giving the error.
Zafar Iqbal
Here are Codes
It is in local environment I was just testing these extension and got this error message, if I use Dynamic SQL Connection there is not error, but I cannot use the SQLi Server behaviors, with any other extension such as Database or Security Assist, because these extensions are not recognizing this extension vise versa when I use Dynamic SQLi Connection with Database or Security Assist then it generate this error I send you the codes.
--------------- PHP Page Starts ---------------------
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
if ((isset($_GET["Search"]) || isset($_GET["Search_x"])) && !isset($_GET["invalid"])) {
$WAFV_Redirect = "products_search.php?invalid=true";
$_SESSION['WAVT_productssearch_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM((isset($_GET["ProductPrice"])?$_GET["ProductPrice"]:"") . "","","",2,"",false,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"productssearch");
<?php require_once('Connections/Conn_WebAssist.php'); ?>
<?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
<?php require_once("webassist/database_management/wada_search.php"); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproducts;
//Searchpage: products_search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("ProductName","ProductName","AND","=",0);
$WADbSearch1->addComparisonFromEdit("ProductMetaKeywords","ProductMetaKeywords","AND","=",0);
$WADbSearch1->addComparisonFromEdit("ProductPrice","ProductPrice","AND","=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_products_results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_products_results"]) && $_SESSION["WADbSearch1_products_results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_products_results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAproducts = 9;
$pageNum_WADAproducts = 0;
if (isset($_GET['pageNum_WADAproducts'])) {
$pageNum_WADAproducts = $_GET['pageNum_WADAproducts'];
$startRow_WADAproducts = $pageNum_WADAproducts * $maxRows_WADAproducts;
mysql_select_db($database_Conn_WebAssist, $Conn_WebAssist);
$query_WADAproducts = "SELECT ProductID, ProductThumb, ProductShortDesc, ProductName, ProductShortDesc, ProductPrice FROM products";
setQueryBuilderSource($query_WADAproducts,$WADbSearch1,false);
$query_limit_WADAproducts = sprintf("%s LIMIT %d, %d", $query_WADAproducts, $startRow_WADAproducts, $maxRows_WADAproducts);
$WADAproducts = mysql_query($query_limit_WADAproducts, $Conn_WebAssist) or die(mysql_error());
$row_WADAproducts = mysql_fetch_assoc($WADAproducts);
if (isset($_GET['totalRows_WADAproducts'])) {
$totalRows_WADAproducts = $_GET['totalRows_WADAproducts'];
} else {
$all_WADAproducts = mysql_query($query_WADAproducts, $Conn_WebAssist);
$totalRows_WADAproducts = mysql_num_rows($all_WADAproducts);
$totalPages_WADAproducts = ceil($totalRows_WADAproducts/$maxRows_WADAproducts)-1;
$queryString_WADAproducts = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAproducts") == false &&
stristr($param, "totalRows_WADAproducts") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAproducts = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAproducts = sprintf("&totalRows_WADAproducts=%d%s", $totalRows_WADAproducts, $queryString_WADAproducts);
// WA Application Builder Delete
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
$WA_connection = $Conn_WebAssist;
$WA_table = "products";
$WA_redirectURL = "products_results.php?ProductID=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "ProductID";
$WA_columnTypesStr = "',none,''";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_Conn_WebAssist;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "3";
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css">
<link href="webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
<style>
form.DetailsPage {
width: auto;
.WADAResults {
font-size:11px;
.WADAResultsNavigation {
border-width:1px;
border-style:solid;
border-color:#BABDC2;
padding-top:2px;
padding-right:2px;
padding-bottom:2px;
padding-left:2px;
.WADAResultsCount {
text-align:right;
float:right;
.WADAResultsNavTable td {}
#WADAResultsTable {
margin-top:5px;
margin-bottom:5px;
.WADAResultsEntry {
padding-bottom:5px;
.WADAResultTitle {
font-size:12px;
font-weight:bold;
.WADAResultDescription {
margin-top:2px;
.WADARecordNavigationButtons {
.WADAResultsBackTop {
clear:left;
.WADAResultsCountBottom {
text-align:right;
float:right;
.WADAResultsNavButtonCell, .WADAResultsInsertButton {
padding-top: 2px;
padding-right: 2px;
padding-bottom: 2px;
padding-left: 2px;
form .WADAResultsContainer input.formButton.ResultsNavButton {
padding: 2px;
-moz-border-radius: 6px;
-webkit-border-radius: 6px;
-khtml-border-radius: 6px;
border-radius: 6px;
outline:0;
form #WADAResultsTable input.formButton.ResultsPageButton {
margin: 2px;
padding: 0;
border-radius: 6px;
outline:0;
.WADAResultsEntry {
text-align:center;
width:33%;
.black_overlay{
display: none;
position: absolute;
top: 0%;
left: 0%;
width: 100%;
height: 100%;
background-color: black;
z-index:1001;
-moz-opacity: 0.8;
opacity:.80;
filter: alpha(opacity=80);
.messageContainer {
display: none;
position: absolute;
top:0;
width: 100%;
z-index:1002;
text-align:center;
height:100%;
#position: relative;
overflow: hidden;
.messageWrapper {
#position: absolute;
#top: 50%;
display: table-cell;
vertical-align: middle;
.messageContent {
background-color:white;
display: inline-block;
padding: 16px;
border: 16px solid grey;
z-index:1002;
overflow: auto;
margin: auto;
#top: -50%;
.WADAResultsTable th{
color: #000000;
background-color: #CCCCCC;
.WADAResultsTableWrapper {
clear: left;
border: 1px solid #CCCCCC;
.WADAResultsRowDark {
color:table;
background-color: #E5E5E5;
.formButton.ResultsPageButton.DetailButton {
background-repeat: no-repeat;
background-position: center center;
cursor:pointer;
width:29px;
height:29px;
background-image:url(images/Icons/view_details.png);
.formButton.ResultsPageButton.DeleteButton {
cursor:pointer;
width:29px;
height:29px;
background-image:url(images/Icons/delete.png);
</style>
</head>
<body>
<div id="Results_Basic_Default_ProgressWrapper">
<form class="DetailsPage Basic_Default" id="Results_Basic_Default" name="Results_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<fieldset class="Basic_Default" id="Results">
<legend class="groupHeader">Results</legend>
<div class="WADAResultsContainer">
<a name="top"></a>
<?php if ($totalRows_WADAproducts > 0) { // Show if recordset not empty ?>
<div class="WADAResults">
<div class="WADAResultsNavigation">
<div class="WADAClearRight"></div>
<div id="WADAResultsNavTop">
<div class="WADAResultsCount">Records <?php echo ($startRow_WADAproducts + 1) ?> to <?php echo min($startRow_WADAproducts + $maxRows_WADAproducts, $totalRows_WADAproducts) ?> of <?php echo $totalRows_WADAproducts ?></div>
<table border="0" cellpadding="0" cellspacing="0" class="WADAResultsNavTable">
<tr valign="middle">
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts > 0) { // Show if not first page ?><input type="button" value="<<" class="formButton ResultsNavButton unstyled" id="First" name="First" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, 0, $queryString_WADAproducts); ?>';" /><?php } // Show if not first page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts > 0) { // Show if not first page ?><input type="button" value="<" class="formButton ResultsNavButton unstyled" id="Previous" name="Previous" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, max(0, $pageNum_WADAproducts - 1), $queryString_WADAproducts); ?>';" /><?php } // Show if not first page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts < $totalPages_WADAproducts) { // Show if not last page ?><input type="button" value=">" class="formButton ResultsNavButton unstyled" id="Next" name="Next" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, min($totalPages_WADAproducts, $pageNum_WADAproducts + 1), $queryString_WADAproducts); ?>';" /><?php } // Show if not last page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts < $totalPages_WADAproducts) { // Show if not last page ?><input type="button" value=">>" class="formButton ResultsNavButton unstyled" id="Last" name="Last" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, $totalPages_WADAproducts, $queryString_WADAproducts); ?>';" /><?php } // Show if not last page ?></td>
</tr>
</table>&nbsp;
</div>
</div>
<table id="WADAResultsTable" border="0" cellpadding="4" cellspacing="0" width="100%">
<?php do { ?>
<tr>
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_WADAproducts){
<td class="WADAResultsEntry">
<div class="WADAResultThumbArea"><a href="products_detail.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?>" ><?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?><img class="WADAResultThumb" border="0" src="images/products/<?php echo($row_WADAproducts['ProductThumb']); ?>" alt="<?php echo($row_WADAproducts['ProductShortDesc']); ?>" width="150"/></a></div>
<div class="WADAResultInfoArea">
<div class="WADAResultTitle"><a href="products_detail.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?>" ><?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?>
<?php echo($row_WADAproducts['ProductName']); ?></a></div>
<div class="WADAResultDescription"><?php echo($row_WADAproducts['ProductShortDesc']); ?></div>
<div class="WADAResultCommerceArea">
<div class="WADAResultPrice"><?php echo($row_WADAproducts['ProductPrice']); ?></div>
<div class="WADAResultCommerceButton"><input type="submit" value="Add To Cart" class="formButton unstyled" id="unstyled" name="unstyled" /></div>
</div>
<div class="WADARecordNavigationButtons"><input type="button" class="formButton ResultsPageButton unstyled DetailButton" value="" onclick="document.location.href='products_detail.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?>
<?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?>';"/><input type="button" class="formButton ResultsPageButton unstyled DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAproducts['ProductID']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" /></div>
</div>
</td>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_WADAproducts && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</tr>
<?php } while ($row_WADAproducts = mysql_fetch_assoc($WADAproducts)); ?>
</table>
<div id="WADAResultsNavBottom">
<div class="WADAResultsCountBottom">Records to <?php echo min($startRow_WADAproducts + $maxRows_WADAproducts, $totalRows_WADAproducts) ?> of <?php echo $totalRows_WADAproducts ?></div>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts > 0) { // Show if not first page ?><input type="button" value="<<" class="formButton ResultsNavButton unstyled" id="First_2" name="First_2" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, 0, $queryString_WADAproducts); ?>';" /><?php } // Show if not first page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts > 0) { // Show if not first page ?><input type="button" value="<" class="formButton ResultsNavButton unstyled" id="Previous_2" name="Previous_2" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, max(0, $pageNum_WADAproducts - 1), $queryString_WADAproducts); ?>';" /><?php } // Show if not first page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts < $totalPages_WADAproducts) { // Show if not last page ?><input type="button" value=">" class="formButton ResultsNavButton unstyled" id="Next_2" name="Next_2" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, min($totalPages_WADAproducts, $pageNum_WADAproducts + 1), $queryString_WADAproducts); ?>';" /><?php } // Show if not last page ?></td>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAproducts < $totalPages_WADAproducts) { // Show if not last page ?><input type="button" value=">>" class="formButton ResultsNavButton unstyled" id="Last_2" name="Last_2" onclick="document.location.href='<?php printf("%s?pageNum_WADAproducts=%d%s", $currentPage, $totalPages_WADAproducts, $queryString_WADAproducts); ?>';" /><?php } // Show if not last page ?></td>
</tr>
</table>&nbsp;
</div>
<div class="WADAClearBoth"></div>
</div>
<div class="WADAResultsBackTop"><input type="button" value="Top" class="formButton unstyled" id="Top" name="Top" onclick="window.location.hash='top';" /></div>
<div class="black_overlay" id="deleteBox"></div>
<div class="messageContainer" id="deleteMessage">
<div class="messageWrapper">
<div class="messageContent">
This will permanently remove the record from your database.<br/>
This action cannot be undone.<br/><br/>
<input type="submit" value="Delete" class="formButton unstyled" id="Delete" name="Delete" />
<input type="button" value="Cancel" class="formButton unstyled" id="Cancel" name="Cancel" onclick="document.getElementById('deleteBox').style.display = 'none';document.getElementById('deleteMessage').style.display = 'none';" />
</div>
</div>
</div>
</div>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAproducts == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">There are no results for your search. Please try again.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
</fieldset>
<input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo($row_WADAproducts["ProductID"]); ?>" />
</form></div><div id="Results_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('Results_Basic_Default', 'Results_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="Results_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
</html>
mysql_free_result($WADAproducts);
--------------- PHP Page Ends ---------------------
Data Assist and Security Assist are not yet compatible with MySQLi... you need to use standard MySQL with those extensions until we put out the next update.
Zafar Iqbal
How about other errors
OK, but hat about the other error messages, did you go one by one through all of the images which I sent you.
I would need a URL to reproduce the problem and FTP access to debug the other errors. I'm not sure of the cause.
If I'm unable to reproduce the errors, then I'll have to set up screen sharing to debug them on your machine where they occur. I'll need a US phone number or Skype contact information to do that.
Zafar Iqbal
How to contact?
The other errors are within Dreamweaver so you do not need URL or FTP, you need my computer access to check for these errors I do not have Skye.
Thank you for the bug reports with CS4. We will look into these further.
