creating a honepot
Thread begun 11/25/2015 5:17 am by Jamie | Last modified 1/05/2017 8:22 am by Ray Borduin | 4589 views | 13 replies |
Jamie
creating a honepot
Hey Ray
Just wondering what I could use in the server validations tool kit to create a hidden element that if has content added stops the form from being submitted (a honeypot). Obviously there is the require/not blank option but wondering if its possible to do the opposite of that to only allow submission if the field is empty?
Cheers
Jamie
You can do a "Like Entry" validation and leave the same as field blank.
Jamie
Thanks Ray
Have added <input name="pot" type="text" value="" style=" visibility:hidden;"> just inside the opening <form> and then added the server validation
if ((isset($_POST["PatientQuestionnaire_submit"]) || isset($_POST["PatientQuestionnaire_submit_x"]))) {
$WAFV_Redirect = "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)) ."?invalid=true";
$_SESSION['WAVT_contact_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["Name"])?$_POST["Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Telephone"])?$_POST["Telephone"]:"") . "",true,2);
$WAFV_Errors .= WAValidateEM((isset($_POST["Email_Address"])?$_POST["Email_Address"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["pot"]))?$_POST["pot"]:"") . "", . "",true,4);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
but for some reason the addition of the server validation is causing the page to error - just a blank screen
As soon as I remove
the page renders fine....
It should be:
$WAFV_Errors .= WAValidateLE(((isset($_POST["pot"]))?$_POST["pot"]:"") . "", "" . "",true,4);
It appears you have to actually enter: ""
when adding the compare to value.
Jamie
oh perfect... thanks mate.
I have tried testing it and the only way I figured I could do that is to change <input name="pot" type="text" value="" style=" visibility:hidden;"> to <input name="pot" type="text" value="some content" style=" visibility:hidden;"> but whether it is the former or the latter, the form still submits... have attached the page
p.s. hope you had a great Thanksgiving
Where did you add the honeypot hidden field? Can I see that page?
Jamie
It's on that page attached to post #5 and is located just inside the opening <form> tag
Your submit button is named: Submit, but the server validation triggers off a form button named: PatientQuestionnaire_submit
You'll either have to update the form button name or trigger to match... currently no server validation is running at all.
Jamie
Gotcha... ok made that correction but now it wont submit at all whether there is a value in the hidden field or if its empty...
Use:
$WAFV_Errors .= WAValidateLE(((isset($_POST["pot"]))?$_POST["pot"]:"") . "","" . "",false,2);
the final argument sets whether it is required or not... it won't accept blank values with it set to true.
