Help with WADbSearch results
Thread begun 11/23/2015 8:21 am by info364504 | Last modified 11/25/2015 10:35 am by Ray Borduin | 3974 views | 10 replies |
info364504
Hi, it works fine with one word searches but it doesn't with a full sentence. Example:
I do a search for Oil and it shows me a list of products with the word Oil in the title, but when I search for Oil vr100 it still shows all the results unless I use "".
All searches are also case sensitive, please help. Thanks.
Is there a url where I can test the search functionality? What version of DataAssist are you using?
Case sensitivity is controlled by the data type of the columns you are searching. You can update your collation settings for the column to use either a case sensitive or case insensitive collation. For instance "latin1_general_ci" or "latin1_general_cs".... the cs or ci at the end stand for case sensitive or case insensitive.
info364504
Thanks, I have fixed the case sensitive problem now.
I now have a different problem: when I search for example for oil xd30 I get the rright results, but when I searh for oil 30 (leaving the xd out) I don't get any results. It's like it only finds exact matches?.
Sorry this code is not online for you to test. Thanks
It looks like it should work.
What does the final where clause look like? You can write it to your page with:
<?php echo($WADbSearch1->whereClause); ?>
info364504
AND ((producto_titulo_esp LIKE '%oil%') OR (producto_titulo_eng LIKE '%oil%'))
That should return any rows with oil anywhere in the column and wouldn't require an exact match. Is there a url where I can test the page?
info364504
yes it does return that.
But the pblem happens when for example I do a search for "oil ultra" and it returns no results eveh though I have items named "oil 4 stroke ultra"
Use:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["searchCriteria"]))?$_POST["searchCriteria"]:"") ."","AND","Includes",",%20","%20",0);
info364504
hanks, that kind of works but not 100%.
This shows all results containing oil and ultra not just the ones only containing those 2 words.
Try this:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["searchCriteria"]))?$_POST["searchCriteria"]:"") ."","AND","Includes","%20",",%20",0);
