Access Denied / Failed login page seems to think user is logged in?
Thread began 11/18/2015 11:40 am by iain331081 | Last modified 11/18/2015 4:11 pm by Ray Borduin | 398 views | 2 replies |
iain331081
Not sure what is happening here - its not a huge issue as it only affects people with a failed login.
But if you look at this page:
http://www.safarilink.com/login/
And try logging in with any random characters, you should get to an Access Denied page.
But the Admin Login link in the footer changes to Logout (I have it set to show Admin Login if people are not logged in, and Logout if people are logged in.)
So I'm not sure why it is changing to 'Logout' on that page.
Also have some code affecting what is shown in the navbar depending on whether users are logged in or not, which shows neither in this scenario, which looks a bit weird.
Have attached a copy of the access denied page below.
Thanks again.
That didn't happen for me.... do you have a separate admin login? Maybe you are still logged in as admin and it is the user login that is failing?
iain331081
Message below...
