url path confusion
Thread begun 11/17/2015 2:00 am by Jamie | Last modified 11/20/2015 2:22 pm by Ray Borduin | 5229 views | 17 replies |
Jamie
url path confusion
Hi Ray
Getting myself a little confused (easy I know!). with regards to yesterdays prem I am trying to get the front end product results page results to link through to the relevant product but with the RS we set up for the level above, am a lot confused what I am doing....just need to get the panels to link through
domain.co.uk/shop/top-cat/sub-cat/productname
The htaccess is currently using
RewriteRule ^shop/(.*)/(.*)$ shop_product_results_s.php?perm=$2 [NC,L,QSA,T=application/x-httpd-php]
RewriteRule ^shop/(.*)$ shop_category_results_s.php?perm=$1 [NC,L,QSA,T=application/x-httpd-php]
and the page is attached and live page in PM
Also, trying to show a message should there be no products listed but it doesnt show the message (it starts at line 193 on the attached)
You have to add the two permalinks to the SELECT statement like:
"SELECT productcategories.CategoryName, productcategories_2.CategoryName AS parentcategoryname, productcategories.CatPermalink, productcategories_2.CatPermalink AS parentpermalink, products.* FROM productcategories INNER JOIN productcategories AS productcategories_2 ON productcategories_2.CategoryID = productcategories.CategoryParentID LEFT OUTER JOIN products ON products.ProductCategoryID = productcategories.CategoryID WHERE productcategories.Live = 1 AND productcategories.CatPermalink = ? ORDER BY productcategories.CategoryOrder ASC"
Then you can do your links like:
<a class="link-text homepagePanelLink" href="shop/<?php echo($Categories->getColumnVal("parentpermalink")); ?>/<?php echo($Categories->getColumnVal("CatPermalink")); ?>/<?php echo($Categories->getColumnVal("ProductPermalink")); ?>"><?php echo($Categories->getColumnVal("ProductName")); ?></a>
and update your .htaccess to account for the product parameter like:
RewriteRule ^shop/(.*)/(.*)/(.*)$ shop_product_details_s.php?perm=$3 [NC,L,QSA,T=application/x-httpd-php]
Jamie
right... i can see what you have done but to say i understand it would be a lie :( sorry but its a lot confusing
now I have to get the target product detail page set up and not sure how to modify the RS / htaccess further and allow the product details to be shown
Also, as you will see on the sub cat pages, there is a navigation set in the right hand column which replicates all the sub cats, I need to also do this on the product results pages and the product results pages so that it shows the sub cat categories on all of them....
also, do i need the recordset 'pagecontents' that I had created prior to usin gthe 'categories' one we created the other day?
$PageContents = new WA_MySQLi_RS("PageContents",$DBConnection,1);
$PageContents->setQuery("SELECT productcategories.*, settings.CompanyName, settings.Town, settings.County, settings.PostCode FROM productcategories, settings WHERE CategoryID = ? OR CatPermalink = ? AND Live = 1");
$PageContents->bindParam("i", "".(isset($_GET['id'])?$_GET['id']:"") ."", "-1"); //paramOffersID
$PageContents->bindParam("s", "".(isset($_GET['perm'])?$_GET['perm']:"") ."", "-1"); //paramPermalink
$PageContents->execute();
or has it become redundant?
You don't need that pagecontents recordset on the sub-page because we are getting the category name from the Categories recordset.
I've already given you the update the .htaccess for the product details page... now you can filter the recordset on the product details page using the perm url parameter filtered against the products permalink column.
You should be able to use INNER join to join the products table to the productcategories table and the parent categories in a new recodset to return all of the subcategories filtering by the products permalink. That query will look something like:
$AllSubs
= new WA_MySQLi_RS("AllSubs",$DBConnection,1);
$AllSubs->setQuery("SELECT productcategories.*, catParent.CategoryPermalink as ParentPermalink FROM productcategories INNER JOIN productcategories AS catParent ON catParent.CategoryID = productcategories.CategoryParentID WHERE  catParent.CategoryID = (SELECT CategoryParentID FROM products INNER JOIN productcategories ON CategoryID = ProductCategoryID WHERE ProductPermalink = ?) AND Live = 1");
$AllSubs->bindParam("s""".(isset($_GET['perm'])?$_GET['perm']:"")  ."""-1"); //paramPermalink
$AllSubs->execute();
(my column and table names may be off since I'm not looking at your database, but that is the idea)
Jamie
sorry... am completely confused on the RS for the product details page... I just dont understand how to modify the RS from the product results page to a) go to the correct product page and b) then to display the relevant product info
$Categories
= new WA_MySQLi_RS("Categories",$DBConnection,0);
$Categories->setQuery("SELECT productcategories.CategoryName, productcategories_2.CategoryName AS parentcategoryname, productcategories.CatPermalink, productcategories_2.CatPermalink AS parentpermalink, products.* FROM productcategories INNER JOIN productcategories AS productcategories_2 ON productcategories_2.CategoryID = productcategories.CategoryParentID LEFT OUTER JOIN products ON products.ProductCategoryID = productcategories.CategoryID WHERE productcategories.Live = 1 AND productcategories.CatPermalink = ? ORDER BY productcategories.CategoryOrder ASC");
$Categories->bindParam("s""".$_GET["perm"]  ."""-1"); //permparam
$Categories->execute();
Just change the where clause from:
WHERE products.ProductPermalink = ?
Jamie
OK, have done that (and added products.ProductLive = 1 and getting a sql syntax error
Notice: Undefined index: perm in /home/motle7bk/public_html/clients/equicraft/shop-product-details_s.php on line 97
which references the variable line
$Categories
$Categories->setQuery("SELECT productcategories.*, productcategories_2.CatPermalink AS parentpermalink FROM productcategories INNER JOIN productcategories AS productcategories_2 ON productcategories_2.CategoryID = productcategories.CategoryParentID WHERE products.ProductLive = 1 AND products.ProdPermalink = ? ORDER BY productcategories.CategoryOrder ASC");
Jamie
$Categories
What URL are you using to access the page? The htaccess rule should be adding the perm URL parameter.
Jamie
ok, the htaccess is
an example of the on page link is shop/for-the-horse/bridles/product-7 which is being driven by the code shop/<?php echo($Categories->getColumnVal("parentpermalink")); ?>/<?php echo($Categories->getColumnVal("CatPermalink")); ?>/<?php echo($Categories->getColumnVal("ProdPermalink")); ?>
