clear cart 'button'
Thread begun 11/11/2015 7:53 am by Jamie | Last modified 11/12/2015 10:51 am by Ray Borduin | 2035 views | 5 replies |
Jamie
clear cart 'button'
Hi Ray
Am using a framework and have created this for the clear cart button:
<a class="glyph headerCartIcons emptyCart" href="#" title="Clear Cart"><i class="icons-cart-remove"></i></a>
so am just wondering how, if it is possible, to 'convert ' the clear cart button that is created in ecart to use the above?
this is the output from ecart
<form name="EShopping_Clear_form_1" method="POST" action="<?php echo $_SERVER["PHP_SELF"];  echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="submit" class="eC_FormButton" value="Clear Cart" name="EShopping_Clear_1">
</form>{
There is a clear cart server behavior you can apply to the page and use whatever trigger you want. The default trigger is "button press EShopping_Clear_1" but you can just as easily use a url parameter from a link to trigger the cart clear.
Jamie
how would i modify it to do that?
Just add a url parameter to your link and then update the trigger to use the $_GET variable.
Jamie
what should the url parameter be?
It doesn't matter... just update the clear cart to trigger off of whatever url parameter you want to us.
