How to choose the right form on login setup page?
Thread began 11/10/2015 3:35 am by Sarre | Last modified 11/11/2015 8:14 am by Ray Borduin | 583 views | 2 replies |
Sarre
Hi
I have several forms on my page where I log in people.
How do I choose my login form in the setup in order to separate it from the rest of the forms?
None of the triggers seems to match my need.
<form class="form-signin" name="loginform" action="">
<input type="text" class="form-control" placeholder="Email" required autofocus>
<input type="password" class="form-control" placeholder="Password" required>
<button class="btn btn-md btn-primary" type="submit">Log in</button>
</form>
Regards,
Sarre
You have to give your form elements name="" properties in order to identify them after the form submits.
If you give your button a name it will show up in the triggers so that you can do different things based on the form button pressed. You will want to give your input fields names as well.
Sarre
Thank you, Ray
Didn't put a name to the form button
