ckeditor absolute file path for images
Thread begun 11/01/2015 12:29 pm by CraigR | Last modified 12/08/2015 11:32 am by Ray Borduin | 6637 views | 9 replies |
CraigRBeta Tester
I am writing an email campaign editor for mailchimp api v2.0 which uses ckeditor, and i want the option to add images to the email.
Is there a way I can configure ckeditor to change the file path of the inserted image to an absolute path, which is needed to display the image ?
Yes. You can set the path in the configuration file and have it include the full URL. It would be the /webassist/kfm/configuration.php file. Just update the "$kfm_userfiles_output" setting to be the full url to the image folder you are uploading to like:
$kfm_userfiles_output = "http://www.yoursite.com/uploadedimages/";
CraigRBeta Tester
Thanks Ray, I'll do that
CraigRBeta Tester
Partial success
When i set this on my local testing server, it worked straight away.
I have now uploaded the changes to my live server, and when i click on the 'browse server button' in the imag properties modal, i get the following errors...
Strict Standards: Declaration of MDB2_Driver_Common::raiseError() should be compatible with & PEAR::raiseError($message = NULL, $code = NULL, $mode = NULL, $options = NULL, $userinfo = NULL, $error_class = NULL, $skipmsg = false) in path/webassist/kfm/includes/pear/MDB2.php on line 986
Strict Standards: Declaration of MDB2_Driver_mysql::setTransactionIsolation() should be compatible with MDB2_Driver_Common::setTransactionIsolation($isolation, $options = Array) in /path/webassist/kfm/includes/pear/MDB2/Driver/mysql.php on line 1122
Strict Standards: Redefining already defined constructor for class kfmSession in path/webassist/kfm/classes/kfmSession.php on line 58
Strict Standards: Non-static method MDB2::fileExists() should not be called statically, assuming $this from incompatible context in path/webassist/kfm/includes/pear/MDB2.php on line 1838
Turn off E_STRICT error reporting... it looks like it is enabled on your live server and I believe if the errors weren't written to the page they could just be ignored.
CraigRBeta Tester
ultimately, i needed to add
error_reporting(E_ALL & ~E_STRICT & ~E_NOTICE & ~E_DEPRECATED);
to the pear/MDB2.php and pear/MDB2/Driver/mysql.php pages to get it working
but work it does !
any update on when you are moving away from kfm, its been a while coming ?
tvtaylor
URL Path
I've made the update to configuration.php file as you suggested, but in the URL path it's adding a "/" in front of the path and removing a "/" in the http://www. part. See attached image. Can you suggest a fix? Thank you.
Can I see a copy of your /webassist/ckeditor/configuration.php file? I'll take a look.
tvtaylor
see attached
The code looks correct to me... if you can provide a URL where I can reproduce the problem and FTP access to your files I will debug it and get it fixed for you.
