Multiple delete records with mysqli
I am in the process of changing all my sites to use mysqli. Is there a way to do repeat region - multiple deletes with the mysqli server behaviours?
Repeat regions, yes. Multiple delete would require some hand coding still, but shouldn't be too difficult to pull off by adding a while or for statement to loop around the deleted records.
