Limitations ?
Thread begun 10/29/2015 6:21 pm by Steve | Last modified 11/03/2015 10:29 am by Ray Borduin | 4604 views | 15 replies |
Steve
Limitations ?
Hello,
Been beating my head against the wall all day and am leaning towards the issue might be an aspect of the MySQLi behavior.
Problem:
I have a MySQLi recordset that should be pulling 29 records but is only showing three. The three is only the records from the first value in an IN () statement.
I've attached the file with comments and will outline what it does in the following steps:
1) Select a Member ID and put it in an array
2) Using a recordset query , poll the DB for any candidates to add to the array
3) Implode the array to have individual values comma separated and reset to the var
4) use that variable in a MySQLi recordset
5) use debugSQL() to see results of final query
Results are:
SELECT tblinventory.invId FROM tblinventory WHERE tblinventory.mid IN ('11','10','20') AND tblinventory.invReleased = 0 ORDER BY rand()
If tested in PHPmyAdmin , 29 records are returned that is accurate for the three values in the IN selector
BUT as a result of the MySQLi recordset behavior only the 1st value in the IN selection is used so only 3 records are the result.
Why is this?
That is because you have the type of the parameter set to be a string... and really it is a comma separated list of integers.
To fix the problem, just change the parameter type of the target parameter you have in your query. It should update line 31 to:
$Recordset2->bindParam("il", "".$mids ."", "10"); //target
Steve
Thanks Ray but I tried that... It removes the leading quotes when as an Integer and still gives the limited results
Screen shot showing those results:
And an SQL error in PHPmyAdmin
Can I get FTP access? I'll have to test it live.... that looks like the result with "integer" and not set as repeated list. Does it have "il" in the code?
Steve
Sure, let me double check and resend you the FTP access we already have set up for you..
I'll also need the url to browse the page.
Steve
details below
Steve
"il" does not render a usable IN string. "s" does a perfect job as shown here:
IN ('11','10','20')
but for some reason it's not working. But the result of debugSQL() does work perfectly fine when executed independently (in PHPmyAdmin). That's why I am thinking there is code in one of the support files that is having trouble with the sql query result even though it is rendered in a usable manner. Security concern?
Steve
I've found that integers also work if you implode the array within the SQL Query.
Granted I am not using the MySQLi Behavior but here is a solution, but we now need to figure how to do this WITH the behavior
// Create connection
$conn = new mysqli($servername, $username, $password, $dbname);
// Check connection
if ($conn->connect_error) {
die("Connection failed: " . $conn->connect_error);
$sql = "SELECT tblinventory.invId FROM tblinventory WHERE tblinventory.mid IN (".implode(',',$mids).") AND tblinventory.invReleased = 0 ORDER BY rand()";
$result = $conn->query($sql);
echo $sql;
$conn->close();
Result:
SELECT tblinventory.invId FROM tblinventory WHERE tblinventory.mid IN (11,10,20) AND tblinventory.invReleased = 0 ORDER BY rand()
1227
1339
2734
1372
516
1681
... etc
It looks like that ftp account doesn't have write access, so I can't debug the files.
The DebugSQL() function just replaces the parameters in the string... it doesn't have the SQL injection security checks the actual parameterized query would run when replacing parameters.
You won't be able to pass in multiple values using "s". If you can update my FTP privileges I'll debug it and get it working for you.
