I am getting an error when I use a plugin
Thread begun 10/29/2015 8:26 am by office42071 | Last modified 10/30/2015 12:44 pm by Ray Borduin | 1563 views | 3 replies |
office42071
I am getting the following error:
Fatal error: Cannot redeclare class WA_AltClassIterator in /var/www/html/adminx/members_results.php on line 114
Can I get a copy of the pages to look at? It sounds like a repeated include file, but they should be using require_once... maybe it is a function actually defined on the page itself? If you provide a copy of the plugin page I can look into it and offer a fix.
office42071
attached
Please attach the actual file instead of copy/pasting the code. It is much easier to read when I can open it with Dreamweaver.
To fix this problem, replace this code:
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter = 0;
$this->ClassArray   = $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter = 0;
$this->ClassCounter++;
    if (
$this->ClassCounter > 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
with this:
if (!class_exists("WA_AltClassIterator")) {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
  function
    if (
      if (
$incrementClass) {
      if (
    if (
      return
    else
      return
That class must be defined on the main page or another plugin and having it twice is throwing the error. By wrapping it with an if statement that checks if it already exists, it should get around the problem.
