Form not submitting
Thread begun 10/28/2015 11:41 am by russb335115 | Last modified 10/29/2015 4:57 pm by Ray Borduin | 3225 views | 9 replies |
russb335115
Form not submitting
I've created a form with check box group that is not submitting. I think it might be because of the value for the value field. Here is a sample, is there anything in the value that can't be there?
Full_Page_Four_Color_Back_Cover_$2440_(1time)_Size:7x10
I think that would still work. The value property is pretty flexible. Do you have a url where I can view the problem?
russb335115
see pm
You have a bunch of repeated .js files on the page. And the jquery files need to be above some of the others that it is currently below.
I'd start by moving:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
above the other script references and then remove any .js files that are repeated... These three particularly:
<script src="webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<script src="webassist/forms/wa_clientvalidation.js" type="text/javascript"></script>
<script src="webassist/forms/WA_ShowCVV.js" type="text/javascript"></script>
Then remove the final jquery reference on the bottom of the page:
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js"></script>
Once you make those changes if you still have issues post back and I'll look at the page again.
russb335115
That work,
Does the webassist function create that link everytime I go in and make a revision and then save it?
The repeated code wasn't causing the issue. It was the order of the jquery code and the additional jquery library reference at the bottom.
It could be adding that code when you make edits through the wizard.
You should still move this to the top of the page:
then the validation code will be styled properly.
russb335115
When you say the top of the page do you mean above the head tag?
I just mean above any other <script> tags... it can still be in the head.
russb335115
Okay thanks,
