redirecting a folder
Thread begun 10/28/2015 7:21 am by Jamie | Last modified 11/04/2015 11:36 am by Ray Borduin | 4552 views | 10 replies |
Jamie
Hey Ray
Am trying to redirect the contents of an entire folder to specific url
eg www.domain.co.uk/subfolder/ to www.domain.co.uk/redirectedurl.php
am trying to get
RedirectMatch 301 /affiliates/(.*) http://www.thevictorianbarn.co.uk/enquiries-booking-form.php
which works fine if its just a folder path that someone is linking from but if someone tries to go to a specific url within the folder, it then appends that file name to the new one.. probably easier to show you. Info in PM
Cheers
Jamie
I don't think you want to use a RedirectMatch 301 type redirect if you aren't redirecting to the specific file in a different folder.
That type of redirect is used specifically for renaming folders. Which means that if you link to a file in the old folder, it will go to the file in the new folder. If you want to just redirect to a single file regardless of the file requested then you would use a standard RewriteRule you can still do a 301 redirect:
RewriteRule ^affiliates(/?.*) enquiries-booking-form.php$1 [R=301,L]
Jamie
thanks Ray... thats rewriting the url to include the path right the way to the server root...
so if you add http://www.domain.co.uk/affiliates/reservations.php gets rewritten to http://www.domain.co.uk/home/domainid/public_html/enquiries-booking-form.php/reservation.php
and if you just do http://www.domain.co.uk/affiliates/ it gets rewritten to http://www.domain.co.uk/enquiries-booking-form.php/ with the trailing slash....
I should have left the $1 off the end... it should just be:
RewriteRule ^affiliates(/?.*) enquiries-booking-form.php [R=301,L]
Jamie
I had tried that but it makes no difference at all...
I just added the rule to the webassist site and it works, go ahead and try it:
RewriteRule ^folderredirect(/?.*) aboutus.php [R=301,L]
maybe you still have one of the other rules in your .htaccess overwriting it?
Jamie
I can see yours working....don't think I have any conflicting (have put my rewrites in the PM).
Can an htaccess file be cached at all?
Maybe try adding:
RewriteBase /
above the rewrite rule... it looks like the server base url is wrong somehow. This might be a general server configuration issue.
Do the article links work properly?
Jamie
Have added that and no difference.....
Yes, the articles work exactly as expected - before and after adding the above
Have you tried:
RewriteRule ^affiliates(/?.*) /enquiries-booking-form.php [R=301,L]
It sounds like the directory setting is wrong in your server configuration. I googled the problem you are having and found that other people solved it in their apache configuration directly:
http://serverfault.com/questions/93195/mod-rewrite-adding-documentroot-to-url
