sort field question
Thread began 10/27/2015 12:27 pm by Patrice | Last modified 10/27/2015 1:22 pm by Ray Borduin | 856 views | 3 replies |
PatriceWebAssist
sort field question
I have a table with numerical field I want to use for sorting for the results page. Field contains numbers like 20, 40, 100 etc. It works great until a field starts with 100. Then the numbers that start with 100 jump ahead of 20, 40, etc. I am assuming that the first number in the field is serving as the sorter. How can I make it use all three digits instead of the first digit?
ORDER BY tenant_location DESC
is the sort being used and results in
100
20
45
66
etc
when I need to have
20
45
66
100
101
Thanks.
Your field type in the database must not be set to a number. If you set the field type to Integer in the database it will sort correctly.
PatriceWebAssist
I'm using a varchar field. Should it be something else?
Ah... integer... Thanks.
PatriceWebAssist
Perfect. Thanks Ray.
