PayPal keeps returning to failure page
Thread begun 10/26/2015 7:18 am by Dave W | Last modified 11/04/2015 1:17 pm by Ray Borduin | 5913 views | 18 replies |
Dave W
I am having a problem with eCart6 since making it live.
When an order is sent to PayPal it returns to checkout failure every time. I have tried several methods of payment (of which I know all have funds), without any luck.
The site worked fine when it was using my own server on my computer, but as soon as I uploaded it the problems started.
I have changed the return address in pp_confirm from the local host to the servername which I presume is correct as before I changed them they where returning to my local server address.
I have attached my pp_confirm page so you can make sure I have made the correct changes for redirect.
Any ideas?
UPDATE.
I have sorted it. It wasn't the pp_confirm page where the alterations were needed.
I did a site search for my local server name and found two occurances on the confirm.php page which I changed for the full URL of the site. I also changed the pp_confirm back to their original settings and all works well now.
It's a shame that I had to do a search to find them, couldn't there be an easier way to change this? I'm sure most people use a local server for testing and this needs to be set up when you first set up the cart. Would it be possible (in the future) for us to be able to change this when we call up the Cart Object or similar?
joerg431091
Sorry for jumping on an older post but I am having the same issue.
After reading this post I also found the localhost reference in the confirm.php page and changed it. But this unfortunately did not do it for you. The paypal window opening still shows the checkout_failure.php page.
If I apply the checkout wizard again and test it on my local machine = it works. But as soon as it is uploaded to the live server the checkout_failure.php page appears.
Any new ideas on this one?
Thanks a lot,
Joerg
This can sometimes happen if you are browsing the the site with www. in front of the domain and then redirect back in the paypal code without it or vice-versa. The solution, if that is the problem, is to use .htaccess to force one way or the other and be consistent.
joerg431091
Thanks Ray,
The site is actually forced using the .htaccess into the www at the moment. Is there a way to change the necessary paypal code to www?
I already changed the Return URL and CancelURL in the confirm.php page to www but that seems not to be the only problem.
$WA_PP_ECO_Set_params[0][$nextIndex] = "ReturnURL";
$WA_PP_ECO_Set_params[1][$nextIndex] = "https://www.tedescohound.com/pp_confirm.php";
$nextIndex = count($WA_PP_ECO_Set_params[0]);
$WA_PP_ECO_Set_params[0][$nextIndex] = "CancelURL";
$WA_PP_ECO_Set_params[1][$nextIndex] = "https://www.tedescohound.com/cart.php?ppcancel=1";
I will attach a copy of the confirm.php page just in case you might see something that does not look right.
Thanks again,
Joerg
That looks correct... what about the pp_confirm.php page... can I see a copy of that?
The next step is to add debug code to the failure page like:
var_dump($_SESSION);
die();
That will give us more information about exactly where and why it is failing.
joerg431091
Of course. I will attache a copy of the pp_confirm.php page.
I added the debug code and it's still live so you can also see yourself by checking out using Paypal at www.tedescohound.com. But I will also attach a text file with the error code for the checkout_failure.php page.
Thanks Ray.
Joerg
The issue is that it is trying to run the authorize.net checkout. I think you can fix the problem by moving the paypal code above the authorize.net code on the confirm.php page.
Just copy lines 225-309 and move them after line 52 instead
joerg431091
Thanks Ray but this unfortunately did not do it.
I will attach a new copy of the confirm.php page as well as the new error message after moving the paypal code above the authorized.net code. Maybe you can spot something.
Thx.
Joerg
Try changing the trigger of the authorize.net server behavior on line 144 to:
if (!isset($_GET["plugin_file"]) && (!isset($_POST["payment-type"]) || $_POST["payment-type"]=="paypal")) {
That should make sure it doesn't run when the paypal code is supposed to.
joerg431091
I did this - but it was actually line 55 of the paypal code as I moved the paypal code before the authorized.net code as suggested earlier.
This does not work unfortunately as changing the code refers the cart.php directly to the paypal checkout without even opening the checkout.php page.
I will attach a copy of the changed confirm.php page to this post but I have changed the code (line 55) back to the previous as I need to have the checkout page come up.
Any other thoughts?
