One Button Works Well while the Other One Doesn't
Thread begun 10/19/2015 4:11 am by salaroche | Last modified 10/22/2015 12:02 pm by Ray Borduin | 4913 views | 12 replies |
salaroche
Hi:
Would anybody know why button No. 1 Sends the right Search parameters to its corresponding Results page while Button No. 2 does NOT?
Button No. 1:
<td><img src="WA_DataAssist/images/Pacifica/GetAttPercent.gif" width="118" height="27" alt="GetAttPercent.gif" onclick="document.getElementById('WADASearchForm').setAttribute('action','-stuattend_ResultsPercent.php');document.getElementById('WADASearchForm').submit();" /></td>
Button No. 2:
<td width="30%"><img src="Images/Buttons/PeriodPerf_Results.gif" width="118" height="27" alt="PeriodPerf_Results.gif" onclick="document.getElementById('WADASearchForm').setAttribute('action','-stuperf_PeriodResultsG1.php');document.getElementById('WADASearchForm').submit();" /></td>
Both lines of code look OK. Their syntax correspond to one another's. Yet, Button No. 1 shows the desired results on the stuattend_ResultsPercent.php page while Button No. 2 does NOT show the desired results on the stuperf_PeriodResultsG1.php.
Any idea why?
Any suggestion would be very appreciated.
Thank you for your attention
salaroche
Actually, I just noticed a discrepancy between the two Buttons: The WADA Search sequence that works has an "any form post" trigger while the other one doesn't. The problem now is that both CS6 and CS5 crash whenever I try to change the trigger to "any form post" in the bad page.
I tried changing the code - if ((isset($_GET["Search_x"]) && $_GET["Search_x"] != "")) { - to - if (isset($_GET["S_name"])) { - but it does not work either (the latter seems to work with the good page).
Please note that the Results Page that doesn't work is a modified copy of the one that works.
Just in case, attached please find a copy of the page in question
Do you have a form element on the search page named" "S_name"?
Is the form method ="get"?
salaroche
Yes to both.... <form action="-stuperf_DailyResultsG1.php" method="get" name="WADASearchForm" id="WADASearchForm">
The Search page has TWO Search Buttons, one that leads to one Results Page and a second Button leading to second Results page. The second (additional) one is the problem.
Please see attached Search Page
It looks like it would work. What is the url so I can take a look?
salaroche
Ray:
Thanks. Unfortunately, right now I don't have those pages uploaded to the Web. I'll upload them later and maybe we can work on this tomorrow. In the meantime, can you tell why the Min(date) and Max(date) functions work well in case No.1 but not in case No.2?
Case No.1:
SELECT oxadmain.name , oxadmain.year , oxadmain.photoID , oxadmain.thumbs , stuattend.ID , stuattend.studid , min(stuattend.date) as fromdate , max(stuattend.date) as todate , stuattend.teacher, stuattend.subject , stuattend.attendance, Count(*) AS RowCount, SUM(if(stuattend.attendance = 'Absent', 1, 0)) AS absents
FROM stuattend INNER JOIN oxadmain ON stuattend.studid=oxadmain.stuid
GROUP BY studid
ORDER BY name ASC
Case No.2:
SELECT oxadmain.name , oxadmain.year , oxadmain.photoID , oxadmain.thumbs , perfgroups1to4.ID , perfgroups1to4.studid , perfgroups1to4.subject , perfgroups1to4.teacher , perfgroups1to4.cw , perfgroups1to4.con , perfgroups1to4.att , perfgroups1to4.attPunct , perfgroups1to4.part , perfgroups1to4.disc , perfgroups1to4.proj , perfgroups1to4.exAct , MIN(perfgroups1to4.date) AS fromDate , MAX(perfgroups1to4.date) AS toDate , SUM(cw) AS cwSum, SUM(con) AS conSum, SUM(att) AS attSum, SUM(attPunct) AS attPunctSum, SUM(part) AS partSum, SUM(disc) AS discSum, SUM(proj) AS projSum, SUM(exAct) AS exActSum, ROUND((AVG(cw)+AVG(con)+AVG(att)+AVG(attPunct)+AVG(part)+AVG(disc)+AVG(proj)+AVG(exAct))/5, 1) AS Avg, cw+con+att+attPunct+part AS ClPerfTot, SUM(disc) AS discTot, cw+con+att+attPunct+part+disc AS Total
FROM perfgroups1to4 INNER JOIN oxadmain ON perfgroups1to4.studid=oxadmain.stuid
GROUP BY studid
ORDER BY name ASC
In case No.2 both Min/Max functions return the date the individual records were entered.
I couldn't say... try simplifying your query and running it directly in phpMyAdmin to debug.
does this query return the results you expect?:
SELECT MIN(perfgroups1to4.date) AS fromDate , MAX(perfgroups1to4.date) AS toDate
GROUP BY studid
ORDER BY name ASC
salaroche
I just tested the exact statement you suggested but I don't get the desired results.
Case No.1 above gives 01-10-2015 and 16-10-2015 as Min and Max dates respectively for ALL records. Case No. 2 gives the record-entry date for both the Min and the Max. The simplified Select statement I just tested also does as Case No. 2.
Anyway, I think I'll make a new copy and redesign the page anew and if I encounter the same problems again I'll contact this forum again.
Thank you for your attention.
salaroche
Ray:
The stuperf_PeriodResultsG1 page seems to be working well now, except for the Min(date) - Max(date) functions, which refuse to return the desired dates. If you'd like to see for yourself please see the private message below
I'm not sure what max or min date you are trying to retrieve. If you use the SQL statement without the max and min:
SELECT perfgroups1to4.date
GROUP BY studid
ORDER BY name ASC
Whatever the first and last date in that query is will be returned as the max and min date when you add those references. You must be using the wrong query to begin with, because MAX and MIN will do what they are supposed to.
Get the query without the MAX and MIN working first, then you can use MAX and MIN to get the highest and lowest value from a particular field.
If you need help writing the SQL statement, that is something I can do in a premier support ticket.
