Simple update with a fields value increment!!
Thread begun 10/15/2015 11:28 pm by Sing | Last modified 10/16/2015 9:29 am by Ray Borduin | 1329 views | 2 replies |
Sing
Hello,
Can anyone Please help me to run this type of command using MySQLi
UPDATE tblName SET hitCount = hitCount + 1 WHERE id = 1
I have tried below options like :
$UpdateQuery->bindColumn("hitCount ", "i", ("+1") , "WA_DEFAULT");
or
$UpdateQuery->bindColumn("hitCount ", "i", ("hitCount" + "1") , "WA_DEFAULT");
or
$UpdateQuery->bindColumn("hitCount ", "i", ('hitCount' + "1") , "WA_DEFAULT");
but no luck. Please help.
Thank you,
Sing
You won't be able to use bindColumn for that. It does SQL injection checks, which will stop that from working.
I think the only solution would be to use a separate query with the same trigger to do the increment. Something like this above your current update record code:
<?php>
if (same if statement as your update) {
$Recordset1
= new WA_MySQLi_RS("Recordset1",$localhost_i,0);
$Recordset1->setQuery("UPDATE tblName SET hitCount = hitCount + 1 WHERE id = 1");
$Recordset1->execute();
Sing
Thank you for your quick response.
I appreciate your quick response.
