CMS
Thread began 10/15/2015 9:14 am by russb335115 | Last modified 10/20/2015 1:11 pm by Ray Borduin | 2389 views | 10 replies |
russb335115
CMS
I have an issue where I've created a "add a page" section using the template function in P-CMS. The link works fine but sometimes when the link is selected the only thing that show is a message "select the edit button to edit content". The actual content isn't showing up. However, if I login to the CMS select that area to edit it and select submit the page shows up fine again.
Is there a reason why this would be happening?
I can't think of why that would happen. Do you have a url and steps to reproduce so I can see?
russb335115
Ray,
Sorry for the delay. See PM
It seems to be working consistently for me. Maybe you made an update?
russb335115
Actually I had to go into the CMS and re-enter the URL so that it worked. This has always been a short term fix eventually it will go back to posting the most recent entry. The one thing that I did notice is that the URL seems to be changing every time I go back into the cms. Sometimes the developer's notes say to add this: ?messages=1
When the client contacts me to let me know that it isn't working again I notice that the developer's notes says to add this: ?messages=1001
So it seems that the original ?messages=1 isn't valid anymore.
I see. Yes... this is because of the drag-drop re-ordering system we added into your CMS.
Since the links depend on the index of the content, and re-ordering changes the index, re-ordering breaks the static links you have made to the content.
I think we will have to find a better fix for you to make links work "permanently" regardless of re-ordering. Can you send me FTP information and I'll suggest a solution after I do a little testing.
russb335115
See PM
I've updated the admin to give you a new method to link to the products that will be more permanent and doesn't depend on the order.
russb335115
Great, so which link should my client use? I see there are two options now.
Use the second one without the number. That way if they re-order it will still work.
