Undefined Variable when in fucntion?
Thread begun 10/15/2015 8:29 am by Steve | Last modified 10/19/2015 9:41 am by Ray Borduin | 1847 views | 2 replies |
Steve
Hello,
Trying to update an old page with new MySQLi code but not able to get past and Undefined Variable being thrown on a simple check for TotalRows == 0
$Recordset1 = new WA_MySQLi_RS("Recordset1",$rtk_i,1);
$Recordset1->setQuery("SELECT * FROM cart WHERE cart.cookieId = ? AND cart.itemId = ?");
$Recordset1->bindParam("s", "".$cookieID ."", "t8mj61d4mbhlq6o1osedmus5f2"); //coookie
$Recordset1->bindParam("i", "".$itemID ."", "2801"); //itemidd
$Recordset1->execute();
// check ItemID and Cookie to see if present?>
<?php //echo $Recordset1->debugSQL();
// delete connection:
include("../Connections/db.php");
switch($_GET["action"])
case "add_item":
AddItem($_GET["id"]);
ShowCart();
break;
case "update_item":
UpdateItem($_GET["id"]);
ShowCart();
break;
case "remove_item":
RemoveItem($_GET["id"]);
ShowCart();
break;
default:
ShowCart();
function AddItem($itemID)
// Will check whether or not this item
// already exists in the cart table.
// If it does, the UpdateItem function
// will be called instead
// Check if this item already exists in the users cart table
if ($Recordset1->TotalRows == 0 ) {
// This item doesn't exist in the users cart,
// we will add it with an insert query
if ("" == "") {
$InsertQuery = new WA_MySQLi_Query($rtk_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "cart";
$InsertQuery->bindColumn("cookieId", "s", "$cookieID", "WA_DEFAULT");
$InsertQuery->bindColumn("itemId", "i", "$itemID", "WA_DEFAULT");
$InsertQuery->saveInSession("id_sess");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
//@mysql_query("insert into cart(cookieId, itemId) values('" . GetCartId() . "', $itemID)");
else
// This item already exists in the users cart,
// we will update it instead
UpdateItem($itemID);
Error:
Notice: Undefined variable: Recordset1 in ..... (more detailed errors in attached screen shot)
Variables defined outside of a function aren't available within a function by default in PHP except for $_SESSION, $_GET, $_POST, $_SERVER, and $GLOBAL variables.
The solution is to define it as a global in the first line of the function like:
global Recordset1;
Steve
Thanks Ray, that solved all my problems... Much appreciated!
