show username
Thread begun 10/13/2015 6:25 pm by natenorbie427772 | Last modified 11/03/2015 5:21 pm by Ray Borduin | 4692 views | 10 replies |
natenorbie427772
show username
I have a home page that has security assist login on it. It has UserEmail and UserPassword to login to "agent" database. That works however would you be so kind to give me a step by step as to how I would show the users email in a table field once they have logged in? Like "Welcome, Nate"? I tried a couple of steps from other questions but there isnt anything that starts with a blank slate. Thanks!
In the authenticate user server behavior you have an option to save one or more fields from the users table as Session variables. Just choose the email field to be stored in the session and then you can display it on any page after they have logged in like:
<?php echo(isset($_SESSION['UserEmail'])?$_SESSION['UserEmail']:""); ?>
(this code assumes you saved it in the session as "UserEmail" but you have a chance to set it to whatever you want in the UI)
natenorbie427772
Working but problem
I got the name to show up after logging in now which is in a "show region" that becomes active along with the name. Problem now is if you go to another page and return the "show region" is still open but the name is gone. Any suggestions. Thanks!
What is the code you are using?
natenorbie427772
<?php echo((isset($_POST["Log_In_group_Email"]))?$_POST["Log_In_group_Email"]:"") ?>
You will want to be using a Session variable value. A Post value only exists when a form is posted to it. Session is the the way to save a value over a browser session across multiple links to different pages.
natenorbie427772
Registration
I have a registration form and fields that are not required are still showing up required on submit, The address is the one cuasing the issues. Here is the code, am I missing something?
Please attach the actual page instead of copy and pasting the contents into the forum. It is much easier to read when I can open it in Dreamweaver and then I can reference line numbers.
In your case, just remove this line of code:
$WAFV_Errors .= WAValidateRQ((isset($_POST["Address_1"])?$_POST["Address_1"]:"") . "",true,7);
it is what is making the address field required. Pages will have both client and sever validation. The client validation is controlled in the form element itself and the server validation is on the top of the page.
natenorbie427772
Captcha not working now
So I had to add a captcha to the register form because of spam. All seemed well however I cannot get the captcha to except my entry. It just refreshes and want me to enter again, and again.
The register form is set up to send an email to the admin once filled out and go to a thank you page. This was functioning until I added the captcha. I assume it still work but the captcha wont validate. I looked over the forums for help but could find a working solution. I have attached my files. Register.php is the file.
You can also test online at www.bgainsurance.com/register.php to see it repeat itself.
Thank you for your help!
It looks like the Session variable reference you are validating doesn't match the Captcha image setting. Try updating line 17 to:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Registration_group_5_Security_code_2"])?$_POST["Registration_group_5_Security_code_2"]:"")) . "",((isset($_SESSION["captcha_Registration_group_5_Security_code"]))?strtolower($_SESSION["captcha_Registration_group_5_Security_code"]):"") . "",true,12);
