MySQLi - multiple LIKE %colname% in recordset
Thread begun 10/09/2015 2:02 am by georgina_barrett_187762 | Last modified 5/12/2017 8:37 am by Ray Borduin | 4607 views | 6 replies |
I am converting a current recordset to MySQLi. I worked perfectly before..
$colname2_booking = "-1";
if (isset($_GET['S_Name'])) {
$colname2_booking = $_GET['S_Name'];
$colname3_booking = "-1";
if (isset($_GET['S_Tel'])) {
$colname3_booking = $_GET['S_Tel'];
$colname5_booking = "-1";
if (isset($_GET['S_Email'])) {
$colname5_booking = $_GET['S_Email'];
mysql_select_db($database_georgeconnect, $georgeconnect);
$query_booking = sprintf("SELECT carpark.*, contractcar.ContractID FROM carpark LEFT JOIN contractcar ON carpark.CarID=contractcar.ID WHERE Company='Ascars' AND carpark.name LIKE %s AND (carpark.tel LIKE %s OR carpark.mobile LIKE %s) AND carpark.email LIKE %s ORDER BY Date DESC", GetSQLValueString("%" . $colname2_booking . "%", "text"),GetSQLValueString("%" . $colname3_booking . "%", "text"),GetSQLValueString("%" . $colname3_booking . "%", "text"),GetSQLValueString("%" . $colname5_booking . "%", "text"));
$booking = mysql_query($query_booking, $georgeconnect) or die(mysql_error());
$row_booking = mysql_fetch_assoc($booking);
$totalRows_booking = mysql_num_rows($booking);
I have researched how you do LIKE %colname% with MySQLi and it works if there is just 1 search field but returns no results if I have multiple LIKE %colname%
$booking = new WA_MySQLi_RS("booking",$georgeconnect_i,0);
$booking->setQuery("SELECT carpark.*, contractcar.ContractID FROM carpark LEFT JOIN contractcar ON carpark.CarID=contractcar.ID WHERE Company='Ascars' AND carpark.email LIKE CONCAT('%%',?,'%%') AND carpark.name LIKE CONCAT('%%',?,'%%') AND Tel LIKE CONCAT('%%',?,'%%') ORDER BY Date DESC");
$booking->bindParam("s", "".$_GET['S_Email'] ."", "-1"); //colname1
$booking->bindParam("s", "".$_GET['S_Name'] ."", "-1"); //colname2
$booking->bindParam("s", "".$_GET['S_Tel'] ."", "-1"); //colname3
$booking->execute();
Try using:
$booking->setQuery("SELECT carpark.*, contractcar.ContractID FROM carpark LEFT JOIN contractcar ON carpark.CarID=contractcar.ID WHERE Company='Ascars' AND carpark.email LIKE ? AND carpark.name LIKE ? AND Tel LIKE ? ORDER BY Date DESC");
$booking->bindParam("c", "".$_GET['S_Email'] ."", "-1"); //colname1
$booking->bindParam("c", "".$_GET['S_Name'] ."", "-1"); //colname2
$booking->bindParam("c", "".$_GET['S_Tel'] ."", "-1"); //colname3
Using "c" as the data type should automatically add the '%' at both ends.
Thank you - I did try that as well but I still get no results. Using this method I do get results if I have a value in each of the 3 fields - even if there is only part of the field in the search - but if any one of them is empty in the url string I get no results.
For example
searchresults.php?S_Name=geo&S_Tel=1&S_Email=g&Search3=Search - this works but
searchresults.php?S_Name=geo&S_Tel=&S_Email=&Search3=Search - this doesn't work
I have even tried
But if any one of the values is empty in the url string I get no results
Try replacing "-1" with "" in each of those lines... that is the value it uses when the parameter is blank.
Yes, that did it thank you!
I am working on a different project using the method above however I have just realised that if a field is empty the search works but if there is a NULL value in any one of the fields I am searching on it doesn't show.
You could not allow null in that column and set the default to an empty string instead.
Another option is to complicate the SQL statement to account for it like:
$booking->setQuery("SELECT carpark.*, contractcar.ContractID FROM carpark LEFT JOIN contractcar ON carpark.CarID=contractcar.ID WHERE Company='Ascars' AND (carpark.email LIKE ? OR (?='' AND carpark.email IS NULL)) ORDER BY Date DESC");
$booking->bindParam("c", "".$_GET['S_Email'] ."", "-1"); //colname2
