Form Builder
Thread began 10/05/2015 11:27 am by russb335115 | Last modified 10/05/2015 12:36 pm by Ray Borduin | 2020 views | 7 replies |
russb335115
Form Builder
I have created a form with web assist form builder. The form doesn't seem to be processing and sending the results via email. Here is what shows in the Address window once the form is submitted.
http://s403739248.onlinehome.us/mastergraphx/jnjda-form2.php?invalid=true
That means it isn't passing the server validation. Did you remove or rename form elements after building the page? That could cause the problem. I'd need to look at the page to tell you the field causing the problem... can you attach a copy of it to a reply?
russb335115
Thanks Ray,
The link is in PM
russb335115
I think you wanted it attached so here it is:
It is the spaces in the form element names. I think you may just need to update spaces with underscores on lines 13-19.
$WAFV_Errors .= WAValidateRQ((isset($_POST["Ad_Text"])?$_POST["Ad_Text"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Total_Cost"])?$_POST["Total_Cost"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Name_For_Box_Ads"])?$_POST["Name_For_Box_Ads"]:"") . "",false,3);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Box_Ad_Phone"])?$_POST["Box_Ad_Phone"]:"") . "",false,4);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Account_Number"])?$_POST["Account_Number"]:"") . "",true,5);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Expiration_Date"])?$_POST["Expiration_Date"]:"") . "",true,6);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Cardholder_Name"])?$_POST["Cardholder_Name"]:"") . "",true,7);
You may need to update the form field names similarly, but it may just need to be updated in the references to them.
russb335115
Okay I did that and now get this:
Fatal error: require(): Failed opening required 'Blank_3.php' (include_path='.:/usr/lib/php5.4') in /homepages/19/d403739231/htdocs/mastergraphx/webassist/email/mailformatting_php.php on line 151
You need to upload the webassist/email folder to the live server.
russb335115
Thanks Ray that fixed it :)
