Email only being sent to one address in recordset
Thread begun 9/29/2015 6:38 am by Daryl | Last modified 9/30/2015 10:52 am by Ray Borduin | 2338 views | 4 replies |
DarylBeta Tester
I have a UE behaviour that sends an email to a loop of addresses from a recordset. I have added this in the Advanced To settings.
It appears that the email is only going to one address:
The Session Dump is as follows
array(14) {
["WAENCRYPTEDRETURNUSED"]=>
bool(false)
["WAENCRYPTEDRETURNSUCCESS"]=>
bool(false)
["WAVT_login_Errors"]=>
string(0) ""
["SecurityAssist_usersID"]=>
string(1) "3"
["usersFirstName"]=>
string(5) "Daryl"
["usersLeader"]=>
string(1) "1"
["waue_emailActivityDetails_1_Status"]=>
string(7) "Success"
["waue_emailActivityDetails_1_Index"]=>
int(1)
["waue_emailActivityDetails_1_From"]=>
string(19) "noreply@fesg.org.uk"
["waue_emailActivityDetails_1_To"]=>
string(27) "email address removed@hotmail.co.uk"
["waue_emailActivityDetails_1_Subject"]=>
string(26) "New Activity - ICE SKATING"
["waue_emailActivityDetails_1_Body"]=>
string(881) "
--WAMULTIBREAKWA
I have tested the SQL in Navicat for MYSQL and get a lot of records.
This page takes nearly 30 seconds from pressing the button to refreshing
The recordset is filtered by a url variable and the form action and redirect on success is set to:
<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".$_SERVER["QUERY_STRING"]); ?>
The session variables would only show the last email sent. Can I see a copy of the page with the email applied?
DarylBeta Tester
I have attached the page below.
This page is a plugin on another page.
If you need to see the page working let me know and I will create an account for you to be able to login
DarylBeta Tester
I assumed it would show a list of email addresses sent to and not just the last one.
This page is probably working as expected then as the email address shown is the last one in the recordset when I run a query directly with the database.
Yes it appears it is all working.
