advance to next record
Thread begun 9/28/2015 9:13 am by mrobben375515 | Last modified 9/28/2015 11:15 am by Ray Borduin | 1401 views | 1 replies |
mrobben375515
I have a page that returns 1 record based on a clicked image from a previous page. We want to allow the user to move to the next record or a previous record in that table. I use mysqli to open the recordset. I tried to apply the mysqli record paging to next and previous record, but when I do, the page gives me a "Error in SQL syntax". The page is http://loyalneighbor.com/inductee.php?id=1
The statement I applied is below. Do I need to do a repeat region first?
<ul class="portfolio-pagination">
<li class="prev"><a href="<?php echo $inductee->getPrevPageLink(); ?>" class="button medium no-bg"><span class="arrow left">&raquo;</span> Previous</a></li>
<li class="next"><a href="<?php echo $inductee->getNextPageLink(); ?>" class="button medium no-bg">Next <span class="arrow">&raquo;</span></a></li>
</ul><!-- end .portfolio-pagination -->
This won't work on a details page and a recordset that only returns 1 record. How are you filtering the recordset? I think you may have to do two more recordsets in order to get the ID of the next and previous records and put in your own navigation that way. The navigation you are using is designed for a page with a repeat region that returns multiple records from the database but only displays a few at a time.
